Old 03-29-2007, 03:13 AM   #1
hewlett2002000
hewlett2002000's Avatar
Homemade Wiring Harness
ok yall i know this is a stupid thing to do, and its not cause im too cheap to buy a painless or something i just want to know if i can do it. i have a couple questions and i hope you can help me. this first one is a very stupid question i know but... does a HEI distributor get the full 12v or is it cut down somewhere? also is the distributor hot all the time until the key is shut off? and im not exactly sure how my alternator wires up. im going to closely study my wiring diagrams i have. everything else i think i pretty much have figured out, but do things ever work out that well? lol. i am building a custom gauge cluster with autometer gauges. any help and/or suggestions would be greatly appreciated.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 03-29-2007, 08:52 AM   #2
flynj1
Re: Homemade Wiring Harness
I did all my own wireing on my 55f100 and drove it for five years without no problem so ye it can be done but you buy an after market is better and easyer most of the time. As for the HEI it gets a full 12volt all the time its running. If you are putting in after market guages they should come with the wire diagrame.
flynj1 is offline   Reply With Quote
Old 03-29-2007, 01:23 PM   #3
Eliasj123
You can do it. It'll just take more time to measure, cut, and crimp.
So, are you going to use the original fuse block and harnesses?? How are you going to approach it??
It would be easiest, IMO, to take the complete harness out of the cab. Then, lay it out to duplicate it.
Elias
Eliasj123 is offline   Reply With Quote
Old 03-29-2007, 01:55 PM   #4
SIR
SIR
SIR's Avatar
....yup ya can do it..BUT to keep yourself from a lot of greaf take the time to solder ALL your connections and shink wrap ALL of them crimp on commectors have a very un-funny way of getting loose and becomiing disconnected,sending you into the darkness for no apperant reason,then comes the wild goose chase trying to find out witch wire it is..TAKE YOUR TIME!! double check EVERYTHING!! and get yourself a curcit tester or a test light these things will help...good luck...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 03-29-2007, 07:04 PM   #5
hewlett2002000
i will probably just take the whole harness out and use that for a diagram. im not really trying to do anything special but the harness that is in there is old and wore out and cut in several places. i will be using a steering column out if a 84 chevrolet and would like to use the ignition switch and blinker switch etc thats on that column. im going to make a custom guage cluster and dash insert that will cover the holes where all that was in the dash. i am going to keep all original equipment for later in case i want a all original truck someday. thanks all for the help.
Respect:
Old 03-30-2007, 01:44 AM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I agree with the solder/shrink way.... ......I've been wirng cars for years.
What I did on the 'Cheif'.....low-budget build....I went down to Kragens and bout two cheap fuse panels...they have like 6-fuses in each.
I use one fuse panel for constant 12v supply (like headlights and tails...brake switch power...radio memory (if so equipped, I dont have a radio )...etc.
The second fuse panel is switched off of the ignition switch (igntion HEI, turn signals, wipers, radio power, etc.)
You have plenty of extra spaces to power...Plus they use newer fuses, and blade connectors. Worked out great for me.
Basically rip out the wiring....leave the headlight pigtail attached, wiper pigtail attached, etc. and build each circuit off the fuse panel one at a time....Use you wiring diagram for sure.
With my truck...most of the wire was OK...but the previous owners (elderly man and his even older brother) were "fart'n around" under this dash...(and pretty much the whole truck
They had one color of wire taped to a 3" piece of another color taped to a 2" piece of another guage wire taped to ...... and so on...it was a mess.
Anyway..good luck...
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-30-2007, 03:09 AM   #7
hewlett2002000
thats john that helped quite a bit. and the 2 fuse panels sound like a great idea. only if i was doing it with 2 fuse panels, on the panel that was running the constant always on 12v i would add a switch hidden right beside the fuse panel so i could turn that off too, so if i had to work on something that was running through that panel or if i got a short or something i could turn it off. thank you alot. i am still confused about the alternator wiring though, i have 3 terminals on my alternator, a BAT, which obviously goes to the battery, and 1 and 2, i have a internal regulator alternator but there is a external regulator hooked up there too, so looking at the wiring in my truck just confuses me more. also im going to have to find a diagram to see what wires go where on the 84 steering column im going to use. its alot of work but im not completely new to wiring, ive done minor jobs on cars and trucks with screwed wiring. i think in the end if i do it right it will be well worth it, because it will be custom tailored to me. anyways, thanks for the help guys.
Respect:
Old 03-30-2007, 03:20 AM   #8
hewlett2002000
replace that with thanks. sorry its 2am and im tired. lol
Respect:
Old 03-30-2007, 04:35 AM   #9
hewlett2002000
ok yall. i got another question. do the headlights, do they get the full 12v? as i said before there will be no switches in the dash except the headlight switch. any switches not on the steering column will be in my custom center console. i was wondering if i can just have 12v going to a switch, then to the high/low button on my column then too the headlights? i found a site that shows how to wire a hot rod and has many diagrams. heres the link if anybody needs it.
http://www.americanstreetmasters.com/wiring_101.htm
i highly recommend you go there, it is very helpful.
Respect:
Old 03-30-2007, 09:36 AM   #10
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The headlight switch itself gets a constant 12v source. The constant 12v fuse panel I meantioned is usually killed by disconeecting the battery.
The GM columns are color-coded, and use pretty much the same color.
I have an old Painless wiring manual from a wire job I did....you can have it if you'd like ?!?
It was for a kit used for 73-87 trucks...very usefull and covers ALL the wiring, which uses all GM color-codes. It would be a good reference, anyway.
It will take care of the ALT and your COLUMN....and then some !!!
Would you likeee ??
Pm me your addy, and I'll send it to you.
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-07-2007, 03:16 PM   #11
evilweevil1
hay guy, newbe here. your GM colume wires like this.
White-brake light switch
Green-right rear turn/brake light
yellow-left rear turn/brake
purple-turn sig. flasher
brown-emergancy flasher
dark blue-right front turn sig.
light blue-left front turn sig.
black-horn
This should be from top to bottom. Sure hope this helps get you going!!
evilweevil1 is offline   Reply With Quote
Old 04-07-2007, 03:55 PM   #12
watahyahknow
watahyahknow's Avatar
Originally Posted by hewlett2002000 View Post
ok yall. i got another question. do the headlights, do they get the full 12v? as i said before there will be no switches in the dash except the headlight switch. any switches not on the steering column will be in my custom center console. i was wondering if i can just have 12v going to a switch, then to the high/low button on my column then too the headlights? .
i've heared if dashes catching fire on chevys because the headlightswitch has the full power going through it when the lights are on .
the wires going through the swich are thick enough when running only the stock lights but the switch itself can get corroded over time and will get verry hot , to prevent this , be able to run thinner wires under the dash and have the lights burn brighter you could use the switch to operate a relay mounted close to the lights themselves the wires from the 12 volt source to the relay and the lights need to be big so they dont get hot the switch in the dash only powers the relay on and off
make life eazier on youreself and all the people having to work on youre truck in a later date : use the original colourcoded wires to make youre own wireloom
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 04-07-2007, 05:32 PM   #13
Bryan59EC
Bryan59EC's Avatar
Routing the headlight circuit thru a relay is a good idea on few levels.
Eliminate hi draw circuit from HL switch---Fire prevention
Dimmer switch and Headlight switch will last forever
Newer halogen headlamps pull more amps than the HL switch is rated for.
Running lamps thru a relay directly from the battery (or buss) makes for much brighter lighting---(my 59 Elky is wired thru relays----way brighter lights)
Two 40 amp relays are needed to do both the hi & lo beams.
No wiring modifications to the switch or inside the cab
about 30-40$ and you have much safer/brighter lighting to the front, and have protected the interior from the only circuit inside the vehicle that is not protected by a fuse.
Bryan
ElCamino 1959 454/5-spd
ElCamino 1966 307/5-spd-----25+mpg
Ranchero 1965 Factory 289 High Performance/4-spd
(uncle bought new)(lil Blue Rocket)
98 Cheyenne EXT cab 350/5-spd
Bryan59EC is offline   Reply With Quote
Old 04-07-2007, 07:27 PM   #14
wild one
Registered.........
wild one's Avatar
Hey Bryan, sounds like a good idea. I bet if someone was to draw up a schematic it would make a nice addition to the FAQ section.
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 04-07-2007, 10:00 PM   #15
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Here you go....A nice Diagram on HOW TO ADD RELAYS TO YOUR HEADLIGHT CIRCUIT.
It's actually a pretty basic install. The best place to mount the relays is next to the Horn relay area (LF fenderwell). I recommend replacing the power-wire from the battery to the horn relay with at least a 10 ga. wire. (If it's not already)
You can now run your fuse/breaker off of the power terminal of the Horn relay.
You can then unplug the headlight harness at the radiator support, and connect those wires to the relays, according to the diagram. You can use blade terminals to insert into stock harness, that way you won't need to cut your harness. (unless you want to).
The LO and HI relay output terminals (87) will now plug into the stock plug in the rad support.
You now have FULL BATTERY LOAD to your headlights...and as Bryan mention, have a cooler harness under the dash !!!!
Hope this Helps !!!
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-09-2007, 12:39 AM   #16
rickf
rickf's Avatar
Since wire choice wasn't mentioned yet, I'll mention it. I always use marine wire and fittings. E.g. Ancor is a brand found at most boat stores. The marine rated wire has more strands for the given wire size (compared to auto or hardware store wire) this makes it more flexible and less likely to break/crack from vibration. It is "tinned", which makes it more corrosion resistent and easier to solder. I also use the stainless marine crimp on fittings. It will cost a little more, but not much considering the amount of wire and fittings needed. In my opinion the longevity and durability are well worth it.
rickf is offline   Reply With Quote
Old 04-09-2007, 08:45 AM   #17
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Good point...great idea, but in this case technically not neccesary. Using this relay set-up alone is a vast improvement over stock...besides the only wire you will need would be just a few inches to jump the relays. (unless your replacing the power-feed to the horn relay). Thanks again...
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-09-2007, 10:14 PM   #18
neto
neto's Avatar
Thank you John, the diagram will come in handy when I start rewiring my son's 65 and my 63.
neto is offline   Reply With Quote
Old 04-15-2007, 11:54 PM   #19
protrash64
Resistance is Futile
protrash64's Avatar
Reading this thread I thought I would throw in a suggestion also.....my truk will be getting some of these ideas when it gets re-wired.........my buddy worked for GM for 20 years anddid numerous programs for GM vehicles; also does extensive work for all types of racing teams (NASCAR, drag, bonneville)...I asked him about the relays and he said he uses them for everything.......I do not have much luck with salvage yards, but, he suggested the relay pack from mid 90's camaros is a nice set up to use. Most 90's cars use something like it.......my buddies camaro has one in front of the drvr side wheel well....something to consider anyway.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
