Slugish
![]() Join Date: Jan 2005
posted this before , noone responded. try again. Is there enough room to install a auto. floor shifter with a bench seat.
yeller
Re: Floor Shift / Bench seat
I am sure it could be done, you will just need to mount it a little higher, and have to reach a little more for it.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
I've done it before, in passenger cars. B&M and others market several kits for bench seat vehicles.,
1970 long fleet, 355 4 speed, primer, walnut goodies |
The Crazy Machanic
or you could fab your own shifter arm to reach the spot you want the nob.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
glamoros piece o' lowlife
I have a regular B&M Megashifter (the truck edition), the way it's mounted right now it looks like it'll clear a bench seat (I have buckets of some kind). If moved slightly more forward and up it will clear a bench for sure, while still being easy to reach and operated. If ya don't want the bulky housing pretty much every ratchet shifter has ya can always use Lokar, they come in like 1500 different shapes and lengths so it's virtually impossible to not find something that works well.
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
Slots go on anything!
If you are looking for a floor shifter, I would suggest Lokar as well. The truck Megashifter has a taller base, and should clear a bench seat as well. I am not overly excited about the ratchet shifters, though. Every one I have had has been a complete PITA to live with.
Chris
Heck yea you can put an auto floor shift in a bench seat truck. We had floor shift 3 speed then 4 speed in a bench seat, and not out in the floor but right in front of the seat on our 76.
Plus most aftermarket auto's have their own plastic console to use, and they have a cable operation, so you can mount the thing on the dash if you wanted to and it still work. No Lie, they sell like 10 ft. cables for them. Now something like the unimatic or indymatic that uses a rod, to shift that may be different since it kinda mounts on the tailshaft. But for a cable operated auto you can put it anywheres, and as others said make your own console as big as you want, or use the one they come with. Most of them are short so reaching them would require a bend down or lean over, where as the rod operated ones usually are taller sticks/handles. Maybe you can find a long handle and change it, or just get creative. Also I know on my hurst vmatic 2 shifter you can cut your old linkage bracket, and weld it to the hurst piece, so you can retain the gear selector in the dash, and the reverse lights and neutral safety work just as they did stock.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
Parts and more parts
I mounted a B&M truck Mega-shifter in my 84 and also one in my Son's 86; both with bench seats. They went in easliy and the cables worked out real well. Plenty of clearance and the proper height was easy to achieve.
paper or plastic?
I've got a B&M mega shifter for trucks. It's been great with my bench seat.
I am putting a Lokar shifter in my other truck though.
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
#10 | |
Slugish
I put the B&M truck shifter in mine. Its cool if you only ride one passenger in your rig. If you have two passengers it cuts down on leg room. I might put back my column shifter again because of this.
#13 |
I have a B&M Unimatic and there is plenty of room for between it and the seat.
#14 |
67-72 Addict!
My truck has a regular (not the taller truck version) B&M Megashifter that works ok. I will probably switch over to the taller one eventually. I like these alot!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#15 | |
The taller mega shifter is the regular one with the addition of two brackets under neath for height adjustment and a taller cover. Last edited by piecesparts; 04-02-2007 at 02:42 PM. |
