Old 03-29-2007, 10:47 PM   #1
chevykevy
chevykevy's Avatar
Neutral Safety Switch Question
I saw a neutral safrty switch advertised on ebay as , 700R4 Neutral Safety Switch. It was manufactured by The Ron Francis Wire Works Co.. When I asked the seller if ther is a difference, or will I need this type of switch when I replace my Turbo 350 with a 700R4, he said "yes". I have read numerous threads on this site concerning the 700R4 swap and no one, that I can recall, has ever mentioned the need to change the neutal safety switch. Anyone with any info on this
chevykevy is offline   Reply With Quote
Old 03-29-2007, 11:19 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Neutral Safety Switch Question
I can't see how they'd be different; someone else may know for sure.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 03-31-2007, 10:33 AM   #3
martinkh
Wouldn't there be a wire hanging out of the tranny that you would use? How would you get a tranny that doesn't have this?
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift.
'77 400sbc, '82 axles, d60front, 14bolt rear.
Probably some 285/75/16 Toyo m/t's on my stock rims coming up.
martinkh is offline   Reply With Quote
Old 03-31-2007, 11:13 AM   #4
cdowns
cdowns's Avatar
the neutral safty switch is mounted on the steering column(or shifter linkage when using aftermarket floor shifts) not the tranny/ there is no wiring from the tranny to the switch
Old 03-31-2007, 11:43 AM   #5
ChevyDude
cdowns is correct. I have a 700r4 and absolutely no electrics go to the transmission. Linkage, speedo cable (you'll need the longer 4x4 cable) , two lines for fluid, filler neck, and your TV...that's it
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
