Old 03-29-2007, 11:24 PM   #1
K Dubb
www.Dubbmotorsports.com
K Dubb's Avatar
Couple questions
Finally got tha T.V. cable on, got it hooked up to tha brackets on tha carb, after i hooked everything us the pedal feels stiff and tha tv cable is getting hung up a little bit, it looks like tha end of the cable is hooked up on tha bracket right its tilted a little bit, when i push tha throttle down the cable goes from being strait to hung up a little bit any idea's? Also, the carb isnt opening all the way with the pedal pushed to the floor. Is the 700r4 and the TH350 dipstick the same?
thx for any help
DubbMotorSports Edition
K Dubb is offline   Reply With Quote
Old 03-29-2007, 11:33 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Couple questions
If you have two springs on you carb or a very stiff one it will make yor petal stiff
Bend the bracket forward a bit it will allow the plastic to not come out all the way. Iv also curved the plstic by sanding it before to make it slide easier.
This is an adjusement issue just need to tenker with it more tell it does, aka move / bend bracket forward.
No there not at least from my 700r4 to my th350 anyway. but my th350 tub is aftermarket but says it just like stock just chrome.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
