03-30-2007, 12:47 AM | #1 |
Blue 67
Emergency/parking brake cable
Well,I got a chance to work on the old rig again. I have switched to 4 disc brakes. Now, I want to hook up the parking brake but the cable seems to be couple inches short even after I elongated it to the max. Does anybody knows how long the stock ones are? and how can I buy one(s) which is longer, I mean is there any particular year model which has longer cables or anybody has had the same problem?
thanks.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
03-30-2007, 01:17 AM | #2 |
Re: Emergency/parking brake cable
http://www.inlinetube.com/ do custom cables. I was going to talk to them. What calipers are you using? I have Eldorado calipers and I'm going nearly three inchs longer than stock. I'd like to know if (and what) others have done. (I've got a Blackbird kit on a D60)
1972 K2500 Long Box 400/350 Last edited by Billhilly; 03-30-2007 at 01:18 AM. Reason: Cuzz I caant spill. |
03-30-2007, 05:49 AM | #3 |
We have a local Tractor Supply store that has the right size diameter cable in stock and we make up our own cables. I think you can buy the ends but I make them from 3/8" rod cut to length with a hole drilled through the middle for our cables. It is just a matter of cutting the cable to length and installing the ends. I use a vise to squeeze the ends and then indent them with a dull chisel to make sure they stay on in lieu of a hydraulic tool.
I believe that Lowe's and other like stores carry cables, also. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 03-30-2007 at 05:50 AM. Reason: spelling |
03-30-2007, 11:20 AM | #4 |
Blue 67
I have blackbird kit for the rear too, with e-brake option. I forgot what kind of the calipers they were. I'll go and look it up. Thanks for info though.
