Old 03-30-2007, 01:29 AM   #1
jimi121v
short water pump & driver side Alt. pics
Can anyone post a good side view of the alt. & steering pump & correct pulleys. I have a 72 that had the alt. moved to the passenger side. I have the correct Alt brackets to move it back, but the the pulley on the Alt. dosn't line up with any of the pulleys on the motor(it's too far back). I have a Vintage Air system on the way that is for short water pump & driver side Alt. So I need to put it back together correctly. It will have short water pump, driver side Alt, and power steering.
Thanks in advance.
Jimi
jimi121v is offline   Reply With Quote
Old 03-30-2007, 02:20 AM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: short water pump & driver side Alt. pics
here are some pic's of the bracket that should be on the 1972 and its on the drivers side hopw this helps the fist pic is the right combo brakets you should have i did a tread on this very problem look up my latest treads and my 1968 3 door the bracks are on it as well if you need more pics i will get somthing going ok have a good one
stsalvage is offline   Reply With Quote
Old 03-30-2007, 02:23 AM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
these are the lower pullies you can't see
Old 03-30-2007, 03:56 AM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
nice burb
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 03-30-2007, 11:19 AM   #5
jimi121v
Out standing! Thanks for the pics. That is exactly what I needed.
Thanks, Jimi
