Old 03-30-2007, 06:23 AM   #1
steveon3
Junior Member
67 chevy k20 spindles
i am looking for a set of spindles for a dana 44 closed knuckle front end. If i cant find then will other spindles work?
steveon3 is offline   Reply With Quote
Old 03-30-2007, 06:29 AM   #2
steveon3
Junior Member
Re: 67 chevy k20 spindles
oh yea the hubs are external with the knob made out of metal with the cover held on by 6 3/8 bolts 4 inches long
Old 03-30-2007, 06:46 PM   #3
I believe you can use up to`69,the last year for closed knuckles.
Old 03-30-2007, 07:24 PM   #4
pickupman
pickupman's Avatar
I may have some used ones, I can check and see
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 03-30-2007, 08:26 PM   #5
john@thepier
john@thepier's Avatar
I have some for sure, is it just the spindles that you need or more? I have the drums and more here, and can let the stuff go reasonably. Let me know if you need pictures.
john@thepier is offline   Reply With Quote
Old 03-31-2007, 06:33 AM   #6
steveon3
Junior Member
the front spindles is all i need right now but you know how that goes. Im fixing up truck that has been setting for 8 years in a field
Old 03-31-2007, 03:27 PM   #7
steveon3
Junior Member
after futher checking it out, i need the small springs that go behind the lockout assembly. some pics would be nice. thanks
Old 04-08-2007, 12:59 PM   #8
john@thepier
Pictures as requested. These are off of a 67 k20 and are in very good condition. Leyt me know if I can be of anymore help. JOHN
Old 04-10-2007, 06:22 AM   #9
steveon3
Junior Member
john pm me .I am interested in the spindles. Thanks
Old 04-10-2007, 10:05 AM   #10
You`d do good to buy up these parts.They`re all obsolete,might not be around next time.Just an observation from a fellow vintage 4wd nut.
Old 04-10-2007, 09:44 PM   #11
steveon3
Junior Member
john i'll take all of it if that is what you want to do. also im looking for a rear brake drum that is off a eaton that has 12" brakes 2 inches wide
Old 04-10-2007, 09:45 PM   #12
steveon3
Junior Member
hey special K, thanks for getting that through my thick pumkin
Old 04-10-2007, 10:04 PM   #13
msgross
msgross's Avatar
are 1/2 ton spindles the same?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
