03-30-2007, 07:52 AM | #1 |
Rottenwood Garage Member
1972 Polly gas tank swap...any fab work needed
I am needing to change out my stock 1972 Suburban gas tank because it is leaking. The polly tanks are cheaper than the steel replacements but I have heard that the fitting (hose) sizes and filler neck tube port are a different size from the original and require some step down hoses. Anyone know? Any truth to it?
Thanks Last edited by 72freak; 03-30-2007 at 07:52 AM. |
03-30-2007, 12:48 PM | #2 |
Re: 1972 Polly gas tank swap...any fab work needed
The neck is a little smaller, but I was able to just clamp the hose down enough to make a good seal. Otherwise it's a direct replacement.
03-30-2007, 12:50 PM | #3 |
They are 1 1/4" o.d. filler necks which are the same as my 67, 68, 69 Panel Trucks, and both my 68 & 71 Suburban have the same 1 1/4" stock necks. To my knowledge 72 are the same, the vent lines were all correct also on these.
GMCPaul |
03-30-2007, 03:23 PM | #4 | |
Whats your price on a polly tank only + shipping to 30067? Thanks Last edited by 72freak; 03-30-2007 at 03:23 PM. |
03-31-2007, 01:51 AM | #5 |
I just put one in my 72 Suburban the only problem I ran into was the neck on the poly tank was not as long as the steel tank and I had to go to NAPA and get a longer piece of rubber gas fill hose. And hold on that hose is not cheap.
03-31-2007, 07:49 AM | #6 |
where did your tank come from?
03-31-2007, 05:35 PM | #7 |
The tanks are oversized so it would cost $15.80 for delivery, are poly tank by itself runs $149.95+15.80shipping=165.75 delivered to your door. You'll find them on the following page of our web site
http://www.gmcpauls.com/fuel_tank_&_related.htm Part#196222 GMCPaul |
03-31-2007, 08:00 PM | #8 |
I ordered mine from MTS directly. I ordered it in the morning and it was here the next day. I had some questions and they were very helpfull. Great people to work with they also had free shipping when I ordered mine. They also have everything else you might need for the install. I halready had a sending unit and was able to use everything else except the J blots and I went to a local Tractor Supply and got them very cheap.
03-31-2007, 08:52 PM | #9 | |
What is MTS and what is there site address? Thanks |
04-01-2007, 08:42 AM | #10 |
04-02-2007, 08:59 AM | #11 |
That is strange I ordered mine from MTS and it was $149.00 plus free shipping no tax and it came with the o-ring and locking collar. I just got it like a month ago. When I looked on E-Bay the cheapest I saw was $138.00 plus $20.00 to ship. The installation was a breeze. With the exception of the length of hose and rusted j bolts.
