Old 03-30-2007, 11:15 AM   #1
Mt Man Chad
Mt Man Chad's Avatar
Question 67~68 VS 69~72 Core support bushings
Who makes correct bushings for 67~68 core supports???? It seems everybody sells 67~72 but they are not all the same!
I am putting togther a couple 67 & 68's and need to find the correct bushings soon!
See link -> http://67-72chevytrucks.com/vboard/s...d.php?t=190626
Does anybody know who has the correct core support bushings kits forsale?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 03-30-2007, 12:06 PM   #2
cabinetguy
67 shorty
cabinetguy's Avatar
Re: 67~68 VS 69~72 Core support bushings
You can make your own.The bushing is a 1/4 " rubber washer.
67 SWB with enough parts to build two
cabinetguy is offline   Reply With Quote
Old 03-30-2007, 12:36 PM   #3
shifty
Questionable
shifty's Avatar
Contact www.gmcpauls.com - I think that's where I bought mine.
69-72 uses a couple of urethane bushings along with a couple of 5/16" 2.5" long carriage bolts and some washers. 67-68 uses two rubber pieces similar to a rag joint with a couple of 5/16" 2.5" long carriage bolts and some washers. I know the 67-68 comes with a special metal piece that you bend down once the bolt is tightened - this keeps the nut from spinning out. You could technically make your own stuff. I have a picture of the setup somewhere around here (GMC Paul's gave it to me), it is very accurate and easy to read, showing what order to stack everything in.
Fastenal.com carries the carriage bolt (it's not a normal size you'll find at Ace Hardware). I can get the part # for you if needed. You're better off just to buy the kit.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-30-2007, 12:56 PM   #4
Bob Moore
Chad - Cabinent Guy is correct. I think it goes like this:
Core-------------
--------- Rubber Washer
--------- Flat Washer
Frame BRK---------
--------- Lock Plate
The Filling Station in Lebanon , OR carries this specific part #CD-88 for $25.00 in the April 05 catalog. Fits 1960 to 1968 Chev/GMC truck.
Let me know what I am supossed to bring to Portland - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-30-2007, 07:41 PM   #5
pickupman
pickupman's Avatar
I also have them available at http://s-c-t-p.com/weat.html
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
