Old 03-30-2007, 11:23 PM   #1
C-10FREK
Upper bag bracket diagrams
Hello Does anyone have a pic with dimension for a upper bag mount so I can make plates to mount to the crossbars on my axle notch. Thanks
C-10FREK is offline   Reply With Quote
Old 03-31-2007, 01:02 AM   #2
randomhero472
randomhero472's Avatar
Re: Upper bag bracket diagrams
pull out the spring, and make a template out of cardboard or thick paper of the upper control arm
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 03-31-2007, 08:26 AM   #3
jlaird
jlaird's Avatar
or you could spend 34.99 and get them at suicidedoors.
jlaird is offline   Reply With Quote
Old 03-31-2007, 09:41 AM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Are you talking about the rear end? I would imagine so since you said "axle notch". If so, all you need to do is take a piece of paper, and trace the bag's port hole and 2 mounting holes, then move that to your frame and drill your holes based on your tracing. It's a 1" hole for the port which is a PITA, but other than that it's pretty simple.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 03-31-2007, 08:59 PM   #5
jlaird
jlaird's Avatar
oh, sorry, thought he was talking about the front. Yea, a template from somebody else isn't really going to do you any good. Everybody's setup is a little different.
