Old 03-31-2007, 12:16 AM   #1
jcfoote60
Active Member
jcfoote60's Avatar
help on a TH350
Guys, I have a chance to pickup a TH350 from a 76 4x4. is the only thing I need to do is to change the adapter from my 72 205?? No spline issues?? Thanks for your advice in advance, I'm not sure the span of years the 72 205 spline pattern was made beyond 1972.......
Jim
jcfoote60 is offline   Reply With Quote
Old 03-31-2007, 06:10 AM   #2
Re: help on a TH350
Are you converting to auto or relacing your TH350?
Old 03-31-2007, 09:46 AM   #3
jcfoote60
Active Member
jcfoote60's Avatar
Re: help on a TH350
I'm replacing an existing one. 3rd gear is slipping badly and I can't afford to just have it rebuilt. I am seeing TH350's from 4x4's pretty regularly on Craigslist from 73 to 80 so was wondering if I just used my adapter would any of these years fit??
Old 03-31-2007, 06:12 PM   #4
customcamper72
Re: help on a TH350
it should be a bolt in if you already have a T-350.
customcamper72 is offline   Reply With Quote
Old 04-01-2007, 08:17 PM   #5
sweet70beast
sweet70beast's Avatar
Re: help on a TH350
Th350 4x4s are a direct bolt in with each other except ones with lock up torque converters and those are easy to spot. 700r4s have the same 4 bolt output and spline count as a th350 but is 2 inches longer, if you ever decided to go that route it will bolt to a 205 t-case and its adapter.
sweet70beast is offline   Reply With Quote
Old 04-02-2007, 02:28 PM   #6
Chris27
Blazerless
Chris27's Avatar
Re: help on a TH350
The output shaft on the 700R4 has the same splines, but is too long. To do this swap you need a short output shaft from Advance Adapters. Stock Th350 T-case adapter is a direct bolt on.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
