Window Installation......
So today i plan on puttin the windows and vent windows in my 66. I was wondering if there was a certain order i should put them in in. I have one vent window in and tried puttin the roll up window in, and i cant get it. Is there an order or is there something special about puttin them in? Thanks....
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] Last edited by SkylineNXS; 03-31-2007 at 12:11 PM. |
Junior Member
Re: Window Installation......
put the window in first but dont screw it in... then get the vent window in and screw/bolt it in place then screw the window to the track.. At least thats how I did it
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
U screw the window in? I didnt know that. Or do u mean keep the window and the roll up harware as a piece and put it all in at once? The way i got it the window was out but everything but the vent window was in. Thanks.....
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] |
Junior Member
Not sure Im following you.. If the only thing that needs to be put in is the vent window and the window is already in, then it should be able to go in with the window down..
Let me know if you need more help
Its not the window thats in, but all the hardware for it is. THe vent window and glass for the roll up window is not in. Thanks....
Mna that was the easiest thing ever, dont know why i didnt do that before, thanks. I just put in the roll up window, rolled it down, then the vent window went right in. Of course, i had to build the passangers side vent window assembly, which i had never done before, so that was fun....a little. Thanks again......
Brad
