Old 03-31-2007, 12:26 PM   #1
boatpuller
boatpuller's Avatar
what tach ?
boatpulller's gonna add a tach,looking for reccomendations and pics if you got them,i just dont want some 6 inch diameter honkin thing.other than that i'm pretty open.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 03-31-2007, 12:55 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: what tach ?
Here is the tach I had in Woody, my old '77 Blazer.
bigblock73 is offline   Reply With Quote
Old 03-31-2007, 01:54 PM   #3
wedgemon
wedgemon's Avatar
Re: what tach ?
Here's mine...
Works good.
= Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 03-31-2007, 03:25 PM   #4
hiway
Mad Scientist
Re: what tach ?
I have the 5" standard Autometer with shiftlight mounted on the lower screw for the windshield piller. It's face matches the other gauges perfectly and it lay's just on top of the dash.
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 03-31-2007, 04:03 PM   #5
boatpuller
boatpuller's Avatar
Re: what tach ?
Originally Posted by wedgemon View Post
Here's mine...
Works good.
= Dave
hey wedgemon,all i see is a red x in a box.don't know if the problem is on your end or mine?
Old 03-31-2007, 04:05 PM   #6
boatpuller
boatpuller's Avatar
Re: what tach ?
hey jeff,that's an old sun isn't it? looks good.
Old 03-31-2007, 04:41 PM   #7
Pyrotechnic
Pyrotechnic's Avatar
Re: what tach ?
http://www.autometer.com/cat_gaugede...gid=2476&sid=1
Thats my personal favorite. 3.75 inch, 8000 RPM. Also comes in chrome as well.
A huge tach that goes to 10,000-11,000 RPM is useless to me. The needle will never reach a large portion of the face, and you end with a needle that barely moves in most driving situations that ends up being harder to read.
Good thing Autometer/Autogage still makes a 5 inch 8000 RPM monster tach though.
Pyrotechnic is offline   Reply With Quote
Old 03-31-2007, 05:40 PM   #8
bigblock73
yeller
bigblock73's Avatar
Re: what tach ?
Yessir. Thanks.
Old 03-31-2007, 08:47 PM   #9
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: what tach ?
I got an old SunPro too, also in the 8k range, it sits under the dash, and actually don't look like it don't belong there:
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 03-31-2007, 11:56 PM   #10
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: what tach ?
factory tack is the best
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 04-01-2007, 11:41 AM   #11
wedgemon
wedgemon's Avatar
Re: what tach ?
Let's try this again...
Founding Member:
Old 04-01-2007, 11:58 AM   #12
bigblock73
yeller
bigblock73's Avatar
Re: what tach ?
A factory tach is indeed nice, but won't do squat for anyone who is running a modified engine or has a performance truck...as the max readout is 5000 RPM.
Old 04-01-2007, 01:49 PM   #13
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: what tach ?
you just cant beat the look of factory tach. but you are true they are not much use with a bulit motor
1967 Chevy stepside
Old 04-02-2007, 07:42 PM   #14
andrist1
andrist1's Avatar
Re: what tach ?
How about running a stock tach that has been reworked by United Spedometer? They should be able to rework the "stocker" to read higher than 5000 rpm. I have seen some of their work, it's tight!
1976 Factory 2wd Blazer - Restored
1975 SWB - Current Project
1978 Big 10 - Just for fun
andrist1 is offline   Reply With Quote
Old 04-02-2007, 10:20 PM   #15
82c10
needin' money
Re: what tach ?
no, it does not get in the way
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 04-03-2007, 07:31 AM   #16
hiway
Mad Scientist
Re: what tach ?
I remember years back when a friend of mine installed the speedo and tach from a late 70 Camero in place of the factory tach and speedo. Looked factory...
07 Suburban
02 Danger Ranger
Old 04-03-2007, 09:13 AM   #17
panelguy
panelguy's Avatar
Re: what tach ?
I put mine in my ash tray. had to do a bit of trimming and then just made an aluminum face to cover the rest of the hole. even left the cigarette lighter in the same location. I know you wanna see pics.... but for some reson I don't have any...yet!!
66 Acadian 2 door
69 GMC panel truck
78 Chevy crew cab dually
79 Chevy blazer 2wd
01 Chevy silverado 2wd reg cab shortbox
panelguy is offline   Reply With Quote
Old 04-03-2007, 09:31 AM   #18
martinkh
Re: what tach ?
If you are building a torque motor, 5k is fine. Read the specs on Crane Cam's MPG series of camshaft, they float the valves @5,500rpm, so a redline of 5k is actually reasonable in that case.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift.
'77 400sbc, '82 axles, d60front, 14bolt rear.
Probably some 285/75/16 Toyo m/t's on my stock rims coming up.
martinkh is offline   Reply With Quote
Old 04-03-2007, 10:01 AM   #19
Eyegore
What Hump?
Eyegore's Avatar
Re: what tach ?
My son placed his autometer tach in his dash
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 04-03-2007, 10:22 AM   #20
neverfinished
Re: what tach ?
are the hole in the aluminum plate the same size as in the stock trim behind it? I was thinking about doing that with my stock bezel but wasn't sure that the gauges would be big enough to fit all the way around the cut outs.
neverfinished is offline   Reply With Quote
Old 04-03-2007, 10:39 AM   #21
boatpuller
boatpuller's Avatar
Re: what tach ?
that looks sweet....did he follow swervin ervins write up or did he do something different? heres a link.."neverfinished" and others might like to read.
http://www.73-87.com/7387garage/inte...s_recessed.htm
Old 04-03-2007, 10:59 AM   #22
Eyegore
What Hump?
Eyegore's Avatar
Re: what tach ?
Yep pretty much, I think he left a little more of the back than mike did, he can sit for hours on end tinkering with stuff until he gets what he wants - must have got that from my wife - lol.
Neverfinished - I think its a larger opening I know he burned up my dremel cutting it out, I think he has to enlarge the opening on the chrome plates to.
Lil red 86 c-10
99 Sub
Old 04-03-2007, 11:33 AM   #23
bigblock73
yeller
bigblock73's Avatar
Re: what tach ?
His are surface mounted, Mikes are recessed. Here is a link to surface mounted gauges.
http://www.73-87.com/7387garage/inte...ge_surface.htm
Old 04-03-2007, 11:58 AM   #24
Eyegore
What Hump?
Eyegore's Avatar
Re: what tach ?
jeff my son hollowed the backing so the gauges would not jump around so much and not rely so much of the surface mount holding them in place. The white backing is still there to fasten the bezel, and he did not do as much cutting to the bezel as shown on mike write-up.
Lil red 86 c-10
99 Sub
