Old 03-31-2007, 05:23 PM   #1
ElkyRacer
z'ing and bagging a 64 Longbed, what would be better?
Ive got a 64 Longbed Im going to start gathering parts to z/notch and bag. Ive got a buddy with a pair of McGaughys 67-70 2.5 drop spindles I can pick up for cheap. What would be better here. I know where to find a whole crossmember/a-arms/ect for a 67-70. I can also pick up a newer 85 model front, and buy drop spindles for it. Which would be better? Did they drasticly change the caster/camber values in the 80s trucks? Would this be a better handling setup? This truck will eventually have a motor weighing right around a BBC, and the truck will be used for car hauling. Would the older stuff be up to the task? Or should I ditch the stock stuff/6lug and go with the newer 80s stuff with 5 lug?
And after all is said and done, when I take it to get aligned, what specs should they align it to. Any special stuff needed to be changed for a lowered truck like this?
Thanks for all your help guys.
Kyle
ElkyRacer is offline   Reply With Quote
Old 04-01-2007, 07:29 PM   #2
ElkyRacer
Re: z'ing and bagging a 64 Longbed, what would be better?
Anyone? Anyone? Bueller? Bueller?
Old 04-02-2007, 01:30 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
I would recommend going with the later model front end and components. The parts are more readily available, and I believe the control arms and bushings to be a better design. Have the alignment shop use the specs for the model year of the front end you use.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-02-2007, 11:40 PM   #4
ElkyRacer
Cool thanks! Has anyone used the later model 3/4 ton stuff? Is it still a sorta bolt in deal too? Im planning on boxing the frame, as 900lbs sitting on the front end is going to be a strain I think. Should I step up in bag size to compensate for the weight? Im totaly new to this bag stuff so bear with me!
Kyle
