Old 03-31-2007, 06:10 PM   #1
wildmanaaron
Difference between 81-91 Blazer and Suburban Frames
Here's the deal. The previous owner of the 1981 Blazer 2WD that I have now cut a few inches off of the frame to install a "custom" bumper off of a Dodge Truck or something. Now I want to install the original style bumpers back on my Blazer. I have done some research in the LMC catalog and determined that the rear brackets for the bumper are the same. But what I want to know is if the frame at the rear is the same for sure.
Does anybody have any pictures of the rear on a 81-91 Suburban that they could post or email me?
Heres some pictures of what they did to my frame rails:
http://www.studentweb.eku.edu/aaron_cowan4/DSC01854.JPG
http://www.studentweb.eku.edu/aaron_cowan4/DSC01855.JPG
wildmanaaron is offline   Reply With Quote
Old 04-02-2007, 02:23 AM   #2
kevinr1970
Re: Difference between 81-91 Blazer and Suburban Frames
Best I can do for you. Hope it helps.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 04-02-2007, 09:58 AM   #3
wildmanaaron
Kevin,
That's a Blazer right? I see a sawzall there...Are you getting ready to cut the frame horns back some? If so I want the frame horns!!
Old 04-02-2007, 01:35 PM   #4
kevinr1970
Originally Posted by wildmanaaron View Post
Kevin,
Yes a Blazer but at that point I was done cutting.
That contraption on the ground was the home-made tow hitch the PO installed. I installed a nice 2" reciever hitch after that.
Unfourtuneatly the PO welded it to the frame behind the horns. You can still see the ends of the angle iron behind the top, inner bumper mount holes. There is no way to put the bolts though those holes now.
I might be able to get you the frame horns from a donor K5 but it will be a while before we get to that point. If you still need them then it would only be shipping cost.
2000 Tahoe Limited
Old 04-02-2007, 01:49 PM   #5
edman87
junk collector
Is that a sway control mount on that hitch? I sure hope no one was pulling somthing big enough to require a sway control with that hitch!
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 04-02-2007, 02:48 PM   #6
wildmanaaron
That would be great. The earlier the better! Thanks for the offer, just let me know when you would be able to get to them. I will pay you for the S&H and for the parts.
Aaron
Old 04-02-2007, 02:53 PM   #7
Jonboy
Slots go on anything!
The suburbans are the same at the rear bumper.
Old 04-02-2007, 03:33 PM   #8
kevinr1970
Actually the hitch was pretty stout - it must have weighed about 70 pounds!
But it looked wrong and I needed a reciever for a bike rack more than a ball to tow with.
I don't think I would ever tow anything that big with a Blazer either way.
2000 Tahoe Limited
Old 04-02-2007, 03:35 PM   #9
kevinr1970
Aaron
Like I said, its going to be a while. I am going to do a body swap from the donor to one of my 2wd's and my buddy is looking for a straight frame.
But neither one of us are in any kind of hurry to get it done.
So it will be a while.
But I will let you know when that time comes.
2000 Tahoe Limited
