Old 03-31-2007, 06:44 PM   #1
northerngmc
northerngmc's Avatar
Separating the steering column from the shaft?
I am in the process of swapping the three speed manual column in my 69 GMC for another 3 speed manual column that I picked up at a wreckers.
I have everything loose and free, but I can't get the splined shaft off the steering column.
Any hints or tricks?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 03-31-2007, 06:57 PM   #2
truckdude239
truckdude239's Avatar
Re: Separating the steering column from the shaft?
there is a bolt in the coupler that has to come out i spented 4 hour the other week trying to remopve mine before i found this out the bolts in the couplers have to come all the way out
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-31-2007, 06:59 PM   #3
northerngmc
I have the coupler bolt right out, but it is still stuck. I had looked at my replacement and saw that the shaft had a small flat section, but not all the way to the end.
What did you do after the bolt came out?
Blaine
Old 03-31-2007, 07:16 PM   #4
cdowns
cdowns's Avatar
i use a wedge chisel to spread the coupler to remove the splined shaft
Old 03-31-2007, 07:38 PM   #5
northerngmc
The coupler seems loose, but the shaft will not come out.
Is the end of the shaft spring loaded?
Blaine
Old 04-01-2007, 01:30 AM   #6
northerngmc
Anybody else?
Blaine
Old 04-01-2007, 01:33 AM   #7
Bob Moore
A picture please. What year is the wrecker column?
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 04-01-2007, 01:45 AM   #8
cstm68
cstm68's Avatar
when i replaced my column the shaft was one piece fron the rag joint to the steering wheel nut i pulled the whole thing through the dash (from the rag joint up) then i put my new tilt next to the old one and cut the steel shaft how long i needed it and then bought a u joint to conncet it
any other questions just pm me
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 04-01-2007, 09:28 AM   #9
truckdude239
pb blaster
David fuller
2000 Tahoe 5.3l 378
Old 04-01-2007, 03:38 PM   #10
northerngmc
It's out, thanks everyone.
I ended up removing the intermediate shaft at the steering box and taking it out as a unit. Once on the bench a small pry bar was all it took to separate the two.
Now to get the new one back it......
Blaine
