03-31-2007, 08:08 PM | #1 |
Gas Tank worked great!
I have recently seen threads on which tank to use and where to put the filler neck. I just got through putting a 69 camaro tank under my shortbed. i made a subframe out of 1 1/2 square tubing and made some hangers out of thin
1 1/2 inch wide flat metal. I bought a new drop back bumper and plasma'd a square hole and covered it with a flip down plate holder off of an 81 malibu. Cant see the tank from behind and everything tucked under nice and fit extremely well! Just though id let everyone know how it went. P.S. picture coming soon hopefully! |
03-31-2007, 08:22 PM | #2 |
Dave's not here, man
Re: Gas Tank worked great!
Did you have to buy the tank new, or did you already have it. Just curious as to the cost of it all.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
03-31-2007, 08:26 PM | #3 |
Cant wait for pics, I wanna do that on my 69 4x4 stepside.
03-31-2007, 08:36 PM | #4 |
yea i bought the tank and sender brand new. i think the whole setup was ended up being about $190 which i thot was very reasonable with the results i got.
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
03-31-2007, 08:49 PM | #5 |
The Original HotRod KnifeMaker
Dave 69 GMC SWB 2WD 454 Turbo 400 |
03-31-2007, 08:51 PM | #6 |
sorry, im looking for them, they seem to have been misplaced!
03-31-2007, 10:30 PM | #7 |
How many gallons?
04-01-2007, 01:00 PM | #8 |
thats the only downfall to this tank: it only holds 17 gallons i belive. And with my 396 and 3.73 posi it looks like i might have to invest in an overdrive tranny
04-04-2007, 11:28 PM | #9 |
Scott, my project is also a 396 with a 3.73 rear end. What is the max rps and speed for you on the freeway?
Thanks!
04-06-2007, 02:45 AM | #10 |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-09-2008, 07:24 PM | #11 |
Please gets some pics up!!
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 Last edited by BP68; 12-09-2008 at 07:25 PM. |
12-09-2008, 09:49 PM | #12 |
Old Skool Club
[QUOTE=Texasbigblock;2103831]thats the only downfall to this tank: it only holds 17 gallons i belive. QUOTE]
The original tank only holds 16 gallons, so you got one more for your efforts.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-09-2008, 11:34 PM | #13 |
How is it filling a gas stations? When you open the cap does it all come spilling out at you?
12-10-2008, 02:30 PM | #14 |
why would it come spilling out? I have no problems with it, works as good as it did on the old cars that were lke this
12-10-2008, 02:39 PM | #15 |
mini truck racer
I always thought about a second gen Camaro tank in this same type of install .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
12-10-2008, 02:46 PM | #16 |
Subscribing for the pics!
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
12-10-2008, 06:41 PM | #17 |
Never Ending Projects
Yeah, where's the pics. This thread was started March of 2007.
Take some new pics please, if you can't find the original one.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
12-10-2008, 07:41 PM | #18 |
Restoring a 68 SWB
It's sort of hard to picture without ummm pictures . From what you said the filler is coming out of the rear bumper. Sorta hard to imagine how the neck would have enough fall on it. I think that's what he's saying.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
12-10-2008, 07:55 PM | #19 |
haha, i guess i better take some new ones before yall show up with torches and pitchforks......im going to go take them right now!
12-10-2008, 09:31 PM | #20 |
anyone having problems uploading pics, keeps sayin there is a security issue? sorry, i was gonna try to get some on here tonight
12-10-2008, 09:55 PM | #21 |
My buddy has a '70 Monte Carlo withe the filler behind the plate, and if you don't do it right gas always spill out. That was what I was thinking.
12-10-2008, 09:56 PM | #22 |
Keep trying!
12-10-2008, 11:52 PM | #23 |
what does this mean ''Your submission could not be processed because a security token was missing''
12-10-2008, 11:56 PM | #24 | |
Restoring a 68 SWB
I am very interested in the camaro tank. 17 gallons would be fine with me. I just don't want to be able to see the tank hanging down below the rear bumper.
12-11-2008, 12:09 AM | #25 |
Not a bad nut after all..
Subscribing for the pictures!
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
