Junior Member
Seat hieght issues
I hope you all can give me some insight here. My truck has been a part for a long time and I'm finally getting it back together. I had the bench seat reupholstered and I recently put it back in. When sitting in the drivers seat I have to slouch to see clearly. I'm looking at the roof line more than out side. I don't remember having this problem before. My seat height from the front mounting point on the floor to the top of where you sit is approximately 12". Is that right? I'm about 6'4. Any one else have this problem? It's wierd because when I drove the thing home after purchasing it I don't remeber this being an issue. I may have to find some different seats to put in--maybe some lower mounted buckets. If someone could tell me the stock seat hieght I would really appreciate it. Also, I would appreciate the measurement from the front of the dash to the back of the steering wheel. I'm wandering how far the steering column (stock) sticks out from the dash. Thanks in advance. This seat issue is really bugging me. Matt
The Older Generation
Re: Seat hieght issues
The seat was probably broken down before you had it redone and after being rebuilt and everything back to original this problem emerged. Also, the upholsterer might have added a little more padding to the seat which would have changed it. I don't know if the seat mounting brackets can be cut down or not. You can look into that too. LockDoc
OzarkHillbilly in Atlanta
Just measured mine,,,,about 12" from floor to top of seat, but my seat is old and worn out. New foam would probably make it higher. I too am 6'4" and have no problem. I could use more space but I guess I've gottin used to it after driving one of these trucks as my daily driver for 6 years.
72 custom/10 LWB 68 Longhorn C20 Custom Camper (sold) |
As far as the steering wheel measurement, If you need more room you can move the steering wheel closer to the dash... Here's how Putter did it. http://67-72chevytrucks.com/vboard/s...d.php?t=191143 LockDoc
