Texas Big Wig
replacing rear yoke, need info ???
Well here's the question, I'm replacing the yoke in my rear-end & need to know if I need to replace the crush sleeve
Also, how much do I torque it to ? Thanks, Matt ![]() |
Resident Absorber
Re: replacing rear yoke, need info ???
sorry I dont have torque specs... but you don't have to do the crush sleeve, it's located between the housing and pinion gear. It would be a good time to replace the seal though
The best offense is a better DEFENSE! |
67 shorty
When you put the yoke back on,tighten the nut until it stops then torque it about an another 1/8 turn or so with a ratchet. DO NOT use an impact gun as this will crush your sleeve. It takes alot to crush the sleeve.
67 SWB with enough parts to build two ![]() |
67 shorty
I took the posi unit with the ring and pinion and spacers and crush sleeve out of my 67 housing to put into my 5 lug 71 housing the other day and this was the method I was told to do by Pat Austin. Livrat reccomended about 80 pnds. as not to crush the sleeve Thats about 1/2 the torque it takes to crush the sleeve. So basically sinch it up then check it after about 100 miles.
![]() Join Date: Jul 2006
The proper way to do it is to pull the carrier and ring gear and torque the pinion nut until proper pinion bearing preload is obtained. it is very hard to GUESS how much torque is needed on a pinion nut to obtain proper preload in a crush-sleeve application. Esentially you need to torque the nut to the point JUST before the crush sleeve begins to crush again.
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
