Old 04-01-2007, 02:05 PM   #1
65-72 chevytoys
65-72 chevytoys's Avatar
Rear end gear oil
How much oil to replace in the rear axle housing. 1 or 2 quarts, or just fill it to the top? What weight oil to use?
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 04-01-2007, 02:54 PM   #2
cdowns
cdowns's Avatar
Re: Rear end gear oil
about a quart and a half/ just keep filling till it comes out the fill hole on the side// i use synthetic mobil one or royal purple 75-90weight
Old 04-01-2007, 02:57 PM   #3
scrapmetalart
Junior Member
Yep. I always use synthetic. Manual trannies & diffs are not something that gets its lube changed all that often. Spent the extra loot on the synthetic!
Fill till it runs out the fill plug as stated above...
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 04-01-2007, 05:25 PM   #4
65-72 chevytoys
Thanks. I just wanted to make sure I would not overfill. I will start with 2 qts.
Old 04-01-2007, 05:50 PM   #5
CMars45000
CMars45000's Avatar
Just a note, Eaton recommends AGAINST using synthetic on their posi units.
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 04-01-2007, 06:12 PM   #6
scrapmetalart
Junior Member
You need posi additive also...correct????
Old 04-01-2007, 06:22 PM   #7
65-72 chevytoys
Thanks for the info but it is just a regular open diff.
