04-01-2007, 02:24 PM | #1 |
TH350/NP205 Complete Set-Up
Recieved this in a recent transaction, But already have a 700R4/NP205 that I'm going to use. So this one's up for sale. PO said that the trany has been gone through, ( I don't know exactly what that means, and have no proof other than these pictures ) From what I see someone has obviously done some work on it. Everything is clean and painted. Inside was also clean other than some paint over spray and the fluide that leaked when I removed the converter was clean. So I have no reason to doubt what I was told.
$500 + shipping ( Would rather not ship for obvious reasons ) I reserve the right to sell this locally !!!! Oh yes, this was a rolling chassis, projeect that was never completed, so what ever was done to it the has 0 miles since. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 04-01-2007 at 07:30 PM. |
04-01-2007, 05:44 PM | #2 |
Re: TH350/NP205 Complete Set-Up
One more Pic. It comes with this deep aluminum pan also.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
04-01-2007, 07:44 PM | #3 |
to bad it has a 2 wheel drive tranny, but the price is still good. To bad you are not closer
04-01-2007, 08:21 PM | #4 |
What makes you think its a 2wd tranny?Im curious...
04-01-2007, 08:43 PM | #5 |
Generally, it's the amount of bolt holes that hold the torque converter inspection cover. A "K-case" uses 6 bolts and is generally considered the heavy duty case and uses a cast aluminum cover with struts that go to the engine mounts... A "2wd" case uses 4 sheet metal screws to hold the sheet metal cover on.
I've seen a fair mix of everything, so I can't really conclusively say which is which/ This one certainly looks 4wd to me, as it has a 205 on the back end of it and it's certainly a sweet deal. Last edited by FormerMember; 04-01-2007 at 09:06 PM. |
04-01-2007, 09:04 PM | #6 |
GMCDAC
Maybe a pickup is different than a Blazer/Jimmy? My '70 Jimmy has 4 bolts holdin on the plastic cover and is absolutely original, and no bracing. 4x4 Blazer and Jimmys were still considered "K" series.
Damm good deal! I wish you were closer also!----DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! |
04-01-2007, 09:08 PM | #7 | |
I think it's actually more of a weight rating. The Th350 and 205 combo I have from a 71 Blazer is the same, 4 sheet metal screws and a sheet metal cover... The 1 ton 73 I took apart is a "K" case. |
04-01-2007, 09:42 PM | #8 |
Active Member
I PMed you.
04-03-2007, 12:37 AM | #9 |
mine is from a 72 3/4 ton
04-03-2007, 07:53 AM | #10 |
