Old 04-01-2007, 05:00 PM   #1
corkscrew
anyone know the cheapest place to buy a horn??? mine is busted
my horn does not shut off is there a way to fix it?
corkscrew is offline   Reply With Quote
Old 04-01-2007, 05:10 PM   #2
cdowns
cdowns's Avatar
Re: anyone know the cheapest place to buy a horn??? mine is busted
chances are its in your steering column or steering wheel especially if you have a non stock wheel// start by taking the wheel off
Old 04-01-2007, 05:27 PM   #3
corkscrew
it would not stop even when i had my stock column on....it just one day once i pressed it just would not go off
Old 04-01-2007, 08:43 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
It's usually one of three things. 1. The button in the column is stuck down. 2. The wire inside the column is shorted. 3. The relay (on the firewall near the column is bad.
The wire from the relay to the button is a ground. If you disconnect this wire and the horn stops honking, the problem is in the column. If it continues the problem is the relay.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-03-2007, 10:33 PM   #5
alschevy
yes call ed from moter trucks 18667556772
alschevy is offline   Reply With Quote
Old 04-03-2007, 11:33 PM   #6
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
1. Open the hood
2. Find the horn.
3. Cut the wires going to it.
4. Should be off now. Just kidding.
FredT posted the same answer I would have wrote.
Did you ever get it fixed?
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
