04-01-2007, 08:19 PM | #1 |
The Original HotRod KnifeMaker
Where is the heater with a shaved firewall?
Where are the heaters, and where are you buying them?
Thanks,
Dave 69 GMC SWB 2WD 454 Turbo 400 |
04-01-2007, 08:24 PM | #2 |
I am a Referee of life.
Re: Where is the heater with a shaved firewall?
Most often the owner installs an aftermarket heater/AC unit.I think there are several companies.Old Air,Vintage Air come to mind.Do a search with the BB vendors and you should be able to get info on each.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-01-2007, 09:26 PM | #3 |
some units are small enough to hide up under the dashboard others ive seen have been relocated under the seat
04-01-2007, 09:38 PM | #4 |
Hot Rod Air is what I will be using. Like cdowns described, the AC and the heat are both contained in a small box located under/behind the dash where the glove box is located.
04-01-2007, 10:47 PM | #5 |
Fabricate till you "puke"
Heater? Oh hell I have an old fat gal to keep me warm.....for 50 yrs old, shes still "on fire" L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
