Old 04-01-2007, 08:22 PM   #1
dave2953
Dave's not here, man
dave2953's Avatar
Water in Cab
It is raining pretty hard out and when I went to move my truck I could feel water hitting my leg. I looked with a flashlight and saw water leaking into the cab from the underside of the dash pad. Is this a windshield gasket or something more serious? Thanks in advance.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-01-2007, 09:12 PM   #2
dave2953
dave2953's Avatar
Re: Water in Cab
ttt
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 04-01-2007, 10:15 PM   #3
centsless
sufficiently talented fool
centsless's Avatar
Re: Water in Cab
The best way to diagnose this is to have smeone hold a garden hose on the outside while you look on the inside for the water. Start at the bottom and work up. Look under the dash while the hose is on that area. It is probably the windshield gasket, or a hole under the cowl screen.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 04-01-2007, 10:16 PM   #4
Re: Water in Cab
It could be the windshield, it may be from another area of the cowl and just running to that spot. There is a body seam in that area under the cowl, the seam sealer could be dried out also. Do come close inspection around your windshield and cowl areas
Man I type slow. The hose idea helps a lot too.
Palf70Step is online now   Reply With Quote
Old 04-01-2007, 10:20 PM   #5
dave2953
dave2953's Avatar
Re: Water in Cab
Thanks for the replies. I will check that out when the rain goes away. All the underdash wiring is soaked, so it's something I need to fix pretty quickly.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
