04-02-2007, 12:20 AM | #1 |
Is it possible?
To put a engine in crooked? I know this sounds like a dumb question and it maybe just me BUT it looks to me that my engine is sitting slightly to the right just a tad. Is is possible to do this?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
04-02-2007, 12:25 AM | #2 |
its all about the +6 inches
Re: Is it possible?
very much so yes
04-02-2007, 12:27 AM | #3 |
Re: Is it possible?
yes it is
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
04-02-2007, 12:35 AM | #4 |
Re: Is it possible?
How can I fix it if it is? Can it damage stuff if it is in wrong?
04-02-2007, 12:36 AM | #5 |
Re: Is it possible?
measure it good first, but if needed you can move the engine mounts on the frame and it could wear out youre carriar bearing alot faster
04-02-2007, 12:38 AM | #6 |
Re: Is it possible?
What would be a good way to measure it? When I say it looks crooked its almost like the dirvers side valve cover is off to the side just a little.
04-02-2007, 12:43 AM | #7 |
Re: Is it possible?
v8? you can measure from the fenders, from the a-arms
04-02-2007, 12:43 AM | #8 |
Re: Is it possible?
or from the frame rails to
04-02-2007, 12:48 AM | #9 |
GEARHEAD
Re: Is it possible?
I agree they can go in there off center as stated just measure form points the same on both sides of the truck. Brake booster may just be thowing your eye off a bit though. Just a thought. RJ22
04-02-2007, 12:50 AM | #10 |
Re: Is it possible?
Its a 350. When you say from the a arms do you mean from one corner to another? What could I use as a reference point?
04-02-2007, 01:10 AM | #11 |
Re: Is it possible?
Someone didn't put a Dodge slant 6 in did they??
-Scott- |
04-02-2007, 01:12 AM | #12 |
Re: Is it possible?
Ok I went out and did some measuring and took some pics of the towers where the mount to the frame.
Here is the passenger side
04-02-2007, 01:13 AM | #13 |
Re: Is it possible?
And the drivers side.
04-02-2007, 01:18 AM | #14 |
Re: Is it possible?
Ok I took another look and I see that on the passenger side tower bolt there is a slight gap but not on the drivers side. Here are the pics.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 Last edited by skokie; 04-02-2007 at 01:19 AM. |
04-02-2007, 02:08 AM | #15 |
Commander Taco Bello
Re: Is it possible?
how about a pic from the angle that you are seeing it appear leaning to one side?
04-02-2007, 02:10 AM | #16 |
Re: Is it possible?
well all of the other pics it looks good but then the last 2 the bolts do look crooked, what measurements did you come up with?
04-02-2007, 02:10 AM | #17 |
Re: Is it possible?
04-02-2007, 05:45 AM | #18 |
Re: Is it possible?
measure the tranny tailshaft.... from shaft to frame, then shaft to frame.
04-02-2007, 01:09 PM | #19 | |
Re: Is it possible?
Will do that tonight.
04-02-2007, 10:40 PM | #20 |
Re: Is it possible?
I had a few mins tonight so I had a look. I checked the area where the bellhousing meets the engine and there are no gaps. Everything is lined up. I think the truck being on a driveway and on a angle is throwing me off.
04-02-2007, 10:49 PM | #21 |
Re: Is it possible?
He meant for you to use the center of the trans shaft for your center point (back by the yoke) and measure to the frame,right and left,to see if the tail is centered.If your motor is crooked,it will project to the trans tailshaft even greater.
04-02-2007, 11:02 PM | #22 |
Re: Is it possible?
Tim, thanks for putting it in the words i was unable to find.
Yes... that is EXACTLY what i ment. Sorry for the confusion. My old 69 GMC was in so crooked that they had to make the shifter bracket longer. |
04-02-2007, 11:51 PM | #23 |
Re: Is it possible?
AHHHH gotcha!! Heading out now. Be back in a bit.
04-03-2007, 12:03 AM | #24 |
Re: Is it possible?
Ok from the inside of the frame to the center of the yoke is 17 inches both ways. So I am crooked not my motor. LOL
04-03-2007, 02:42 AM | #25 |
Re: Is it possible?
happens to the best and worst of us
