cutting aluminum???
ok yall i got a question. im making a custom gauge insert and i have a sheet of aluminum i need to cut. ive tried cutting aluminum before without good results. i can cut the shape out but how do i cut the holes for the gauges and still make it look nice? please help....
thanks, John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
Re: cutting aluminum???
I always have used a hole saw or have a machine shop cut it, eihter way, it shouldn't be too hard or pricey.
Newbie truck Rebuilder!
Machine shop is the way to go, we have a cnc mill here where I work, and I machined mine out on a Haas machine....you can't beat it, and having it done professionally will be worth the money....
"Old Blue" 1964 GMC Fleetside in pieces 350 TPI with 700R4 tranny now installed( well kinda propped in place until the tranny crossmember is bolted in ![]() 1995 Toyota 4runner , 197,000 miles and going... ![]() 2007 Honda Odyssey Van (Wifes car) ![]() ![]() |
I work at a machine also, and all i gotta say is that would be the best route to go. CNC's are one of the best things to use. Aluminum is in general pretty soft so u could use a whole saw and then file the circles to make em look a little nicer, then just take some fine grit, fine fine grit, paper and it should shine up, then finish with some scotch brite......
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] Last edited by SkylineNXS; 04-03-2007 at 12:40 AM. |
