Old 04-02-2007, 01:32 AM   #1
cstm68
cstm68's Avatar
richmond trany ?
has anyone here used a richmond 4+1 five speed transmition in there truck?
can i use my stock clutch set up if i use my original bellhousing that wil bolt to the new trany ? or do i need a hydraulic clutch setup ?
here is the trany
http://store.summitracing.com/partde...5&autoview=sku
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 04-02-2007, 11:28 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: richmond trany ?
You need a 26 spline disc, & you can use the stock bell(go 67 or older for the centerhole in the truck bell), & all the stock linkage will work. I cant help on lenght of the trans however, as I have a Richmond 6 spd in my truck. L http://community.webshots.com/user/hotrodhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
