Old 04-02-2007, 07:24 AM   #1
-Greg72
-Greg72's Avatar
Porterbuilt Tire/Wheel sizes....20's & 22's
I know the answer is buried in one of these posts, but I can't find it.....
A couple of the Porterbuilt trucks (including the Panel) are setup using a 20" wheel up front with a 255/35-20 tire (approx. 27.03" diameter) and the rears are a 22" wheel.......but I can't find the tire size????
I think I've seen where the rear tire diameter was described as 29" in some discussions....but the closest tire I've found to match that is a 285/35-22 (approx. 29.85" diameter)????
Anyone able to clue me in???
Thanks!
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s
Find me on INSTAGRAM @MIGHTASWELLK5
'72 K5 - Greg's "Might As Well™" Build
-Greg72 is offline   Reply With Quote
Old 04-02-2007, 09:31 AM   #2
skunkwerx
skunkwerx's Avatar
Re: Porterbilt Tire/Wheel sizes....20's & 22's
265-35-22
skunkwerx is offline   Reply With Quote
Old 04-02-2007, 09:48 AM   #3
-Greg72
-Greg72's Avatar
Originally Posted by skunkwerx View Post
265-35-22
Thanks! That puts it at 29.30"......pretty close to the 29" I thought I'd remembered reading about.
Old 04-02-2007, 03:00 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
295 30 R22... 29" diameter
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-02-2007, 03:07 PM   #5
-Greg72
-Greg72's Avatar
Even better.....accurate info!
Thanks, in case you can't tell I'm still "studying" and trying to understand as much as possible before placing my order.
At this point, I'm basically settled on a C4 Dropmember with the C4 rack & pinion. Will the ART Air-Bar (bolt-on 4-Link) get me all the way down in the rear on a 29" tire?.....or should I chill-out and wait for your rear suspension design to be completed?
Old 04-02-2007, 03:52 PM   #6
jimmydean
jimmydean's Avatar
I have never considered the C4 as "settling" I will be running the C4 rear, but I am torn between the standard dropmember and the C4 version. Only because I have invested in the front already, so I have some of the parts on hand.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-02-2007, 04:01 PM   #7
-Greg72
-Greg72's Avatar
If you were running a solid rear axle (which I am)....what's your take on a good rear suspension setup??
The Air-Bar looks like a well-engineered design, and simple because I don't have to do much other than just bolt it in. However, I don't know for sure if it's intended to "lay frame" or not.
I know that a certain amount of cutting is going to be necessary out back to get all the way down (driveshaft clearance, frame notching....maybe more) but I'm hoping that by staying with a decent diameter tire, like the 29" variety we've been discussing.....the mods won't become excessive out back.
Old 04-02-2007, 04:31 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
I am waiting on Air Ride's new Strong Arm kit for the rear to get here so I can play with it. I have a 62 panel (my new shop truck ) I set on a 66 Sub. frame and it has a Dropmember up front. I will be putting the Air Ride stuff on the rear and will find out what is needed to get it down. I do know there will be "extensive mods" to make it happen... if a big notch is considered to be "extensive". The 63 panel referred to earlier has a c-notched frame and is as low as it can get with such.
You had mentioned towing with your burb... it will be quite a bit of work to lay frame and keep the structural integrity of the chassis in order to safely tow.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
