Old 04-02-2007, 12:57 PM   #1
Ole Blue 68
Ole Blue 68's Avatar
Turn Signal Help
I found this one out over the weekend and it's got me scratching my head. My right rear turn signal does not work. The bulb is fine and the right front signal and sidemarker both blink.
What do you all think?
Ole Blue 68 is offline   Reply With Quote
Old 04-02-2007, 01:15 PM   #2
68speedalert
Semi-Senior Member
68speedalert's Avatar
Re: Turn Signal Help
Get a 12 volt test light and learn how to use it.
Does the brake light work on that side?
Could be wire broken if the brake light doesn't work, could be ground is bad,....etc.
If brake light DOES work, likely turn signal switch.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 04-02-2007, 01:54 PM   #3
Ole Blue 68
Didn't check the brake light so I'll start there.
Old 04-23-2007, 05:12 PM   #4
Ole Blue 68
Re: Turn Signal Help -Update-
You gotta love when you find a simple answer to a problem....
Finally got to looking into this problem and it had me scratching my head for a couple of minutes till I took 68speedalert's advice and got out my 12 volt test light and started poking around. Turns out that the bulb was good but it was the WRONG bulb. The contacts weren't matching up which is why only the taillight was working.
