Old 04-02-2007, 04:19 PM   #1
Olden Days
Living In The Past
Olden Days's Avatar
correct application, bumper brackets
I know the rear brackets are different on a 71 4x4 short bed vs 2 wheel drive. somewhere I got the idea that the front were the same though. Is this correct or not. Thanks
Olden Days is offline   Reply With Quote
Old 04-02-2007, 06:37 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: correct application, bumper brackets
It seems like the fronts are the same. And yes the rear are different due to a 4x4 having spring hangers in the way. A coil spring truck doesn't have this issue.
see ten is offline   Reply With Quote
Old 04-02-2007, 08:43 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
The front brackets are different between 2wd and 4x4 to clear the front spring hangers.
The inner rear brackets are different between the SWB 4x4 and a coil spring 2wd or a LWB leaf spring 2wd. The 4wd SWB and 2wd SWB leaf spring brackets are the same. I believe the outer brackets may be the same. This assumes the sport bumper, not the step and tow variety
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
