04-02-2007, 06:20 PM | #1 |
Is this what i can expect?
I was at a car show last saturday in Atlanta, and came across this truck.
After looking at it for a bit i noticed the grill and fenders arent lined up well. My question is is this due to poor repro quality, or are the fenders and grill not linged up properly? If this truck belongs to anyone here please dont be offended by me pointing this out, I simply want to know if the grills are a good fit or not. David Last edited by TheSasquach; 04-02-2007 at 06:21 PM. |
04-02-2007, 06:35 PM | #2 |
WTB this ad
Re: Is this what i can expect?
Odds are the problem is aftermarket fenders. Where the fenders make the first 90* bend toward the center of the truck, they don't go far enough before they make another bend toward the front of the truck. We didn't realize this on my K10 until we went to mount the grill. However we didn't leave things like this fella did. The dolly and hammer was broken out and the fenders got the extra roll they needed. Then they had to be painted again.
04-02-2007, 06:41 PM | #3 |
yeah you have to expect to massage everything prior to paint to get a great fit even oem stuff might need some work// alot of "builders" its a streach of thier talent to just open the boxes up and the final assembly shows it
04-02-2007, 07:00 PM | #4 |
These older vehicles were not built to the tolerances of today's standards and many people do not realize that until hey get in to building one. Sometimes you have to "persuade" the parts into fitting!!
04-02-2007, 07:17 PM | #5 |
I am a Referee of life.
This is one reason the price of pro builds is so high.Usually they build the truck completely,in primer.Any adjustments like this one can be made,all the brackets ect. are drilled correctly,all of the parts test fitted.At one time builders would do all this and even drive the vehicle for a while.After that it was blown all apart and any fixes performed then it was off to paint and final finish work.Over time most pro shops have determined what has to be done and they just do it.Before everyone used JY parts and had to massage or modify them to fit so it was a little more involved.Now everyone uses well engineered kits for suspension and such so that part is already good to go.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-02-2007, 08:44 PM | #6 |
After looking at the pictures again it may be one of the chromed grilles that everyone is talking about that do not fit very well.
04-02-2007, 08:47 PM | #7 |
Resident Curmudgeon
I think it may be the chrome grille at fault here
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
04-02-2007, 08:58 PM | #8 |
sufficiently talented fool
I'll third that opinion
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
04-02-2007, 09:07 PM | #9 |
Is there one supplier that is more likely to have "better" ( needing less massaging) than others, or is there one (or more) to avoid? David
04-04-2007, 02:38 AM | #10 | |
********************************************************** With me it was the grill assembly as I have the original fenders on my truck. I went through 3 grill kits and on the third one I had to modify things to get the best fit that I could. The two tone paint scheme really shows this up more so then if it were one color. The kit was supplied through a local hot rod shop who uses Classic Industries who I think have a really crapy attitude with regards to customer service!! I would never use their products from them or a dealer who uses them as a supplier again! The dealer gave me a $180.00 in store credit and I wrote a tech article for him how to install the grill which is included with every grill he sells. esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 04-04-2007 at 02:42 AM. |
04-04-2007, 06:56 AM | #11 |
It`s that steel chromed grille.It just doesn`t have the proper radius and is not the proper measurement to fit over the mating area.No fenders are made that bad.That grille would never fit over that are with any amount of "massaging".The grille is a poor custom chrome piece never made by the factory.LMC produced them,initially.Then,became available to all vendors.
It`s a shame after all that work that a guy pays good money to screw his truck up with crap parts.
04-04-2007, 07:46 AM | #12 |
This is actually pretty common to see at shows. What surprises me is when a vehicle wins and looks like that. Most people wouldn't even notice it if they weren't looking or didn't have one themselves.
I would have sent that grill back, there's no sense in companies putting out products like that. Especially for the money we shell out for parts. My wife actually made a good comment on this the other day while watching a build on tv with me (they were massaging a quater panel) she said "you know after fifty years (the car)you would think a company could get the measurments right"
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some ****in' muscle. -Wooderson From the movie Dazed and Confused |
04-04-2007, 01:48 PM | #13 | |
Re: Is this what i can expect? Hood appears too short.
********************************************************** Hello there Speicial-K, Do you know if a 67 > 72 GMC P/UP is supposed to have a gap between the top bar on the grill and the hood? I have seen old work trucks not hot rods and this is the case. The hoods appear to be adjusted properly on the sides and the back closest to the windshield. The hood appears to be too short in the front. esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 04-04-2007 at 01:50 PM. |
04-04-2007, 03:37 PM | #14 |
My chrome steel grill fits way better than that........Ill try to post pics tonight....
1972 Chevy 1/2 ton on 1981 chevy 3/4 ton 4X4 chassis! 8" lift Frame off resto. |
04-04-2007, 03:53 PM | #15 |
DAMN that's a nice truck, kinda sucks about the grill alignment.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
