Old 04-02-2007, 07:15 PM   #1
nvrforgotten52
nvrforgotten52's Avatar
proportioning valve
im thinking of going with this front disk kit. http://classicheartbeat.com/catalog/...sion%20Kit.htm i believe im going to need a new prop valve. im still going to have rear drums just the disks up front. which valve should i go with and where can i find it.and is there anything else i would need that the kit doesnt come with. thanks.
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 04-02-2007, 07:38 PM   #2
GMCPaul
Re: proportioning valve
You'll also want a disc/drum master cylinder. You can get by just using a adjustable prop valve to adjust pressure keeping the original master cylinder, but in order to get the full benefit of switching to disc brakes you'll want a disc drum master cylinder which has a larger resevoir to compensate for the addition of disc brakes.
I believe Wes at Classic Heartbeat should be able to help with both parts. If not you'll find both of them on our web site.
GMCPaul
GMCPaul is offline   Reply With Quote
