04-02-2007, 08:54 PM | #1 |
Need Help Badly
I have a 70 c-10 that the PO changed to disc brakes. The problem is the only numbers I can find are in the hub assembly they turned into a rotor,it is a gm number but I cant seem to be able to find it anywhere the number is 383310 with either 80 or SD at the end I need to replace the wheel bearing and cant.
04-02-2007, 09:00 PM | #2 |
Dave's not here, man
Re: Need Help Badly
Have you checked the wheel bearing itself for a part number, or is that number you listed from the wheel bearing?
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
04-02-2007, 09:18 PM | #3 |
Re: Need Help Badly
Ya I checked it but there gone on the bearing,that number is from the hub
04-02-2007, 10:41 PM | #4 |
its all about the +6 inches
Re: Need Help Badly
find a good parts guy, and ask for the P/N for a 71 inner and outer, then an 80 inner and outer, and then an 86 inner and outter.
if my suspicions are right... it's the same. |
04-02-2007, 10:52 PM | #5 |
Re: Need Help Badly
Or take your bearings to a parts house and find a patient counterperson to match them. I work at a Carquest and thats a normal routine. At the store I work at, there's only about 30 or so sets of bearings and races that are your typical wheel bearings, so it doesn't take that long if you don't have a number to go by.
