04-02-2007, 09:51 PM | #1 |
bypassing an EGR Valve...
so can it be done? and if so how?
04-02-2007, 10:05 PM | #2 |
The Crazy Machanic
Re: bypassing an EGR Valve...
I know edelbrock makes one. For non egr intakes. what the do is just put a block off plate were it would be in the intake. Id surch edelbrock for it cause im shure they would sell it by it self.
What it does ids yoy just remove the egr valve and bolt the plate on it.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
04-02-2007, 10:43 PM | #3 |
Parts and more parts
Take the EGR off of the manifold and make a flat plate to cover the holes. The EGR takes gas in and out through the holes in the manifold. Don't forget to cap off the vacuum source.
04-02-2007, 11:59 PM | #4 |
Don't forget, if you're using a carb that's calibrated for use with EGR, you'll likely get some part-throttle pinging if you ditch the EGR.
04-03-2007, 05:06 PM | #5 |
Insert Witty Text Here
My EGR had a spacer that went between it and the intake. I used it as a pattern to cut a blockoff plate, then put the spacer on top of the plate to strengthen it up. I then bolted the plate and the spacer in place of the EGR valve. A thicker plate would have worked better, but I used the only metal I had.
Slonaker |
04-03-2007, 07:20 PM | #6 |
ok.. i c thanks guys
