04-03-2007, 12:56 PM | #1 |
Anyone have a 15" steering wheel with NON power steering truck?
Just as the title says. I really want to add a grant "classic" wheel to my truck.
But my truck does not have power steering, nor do I plan on adding it, at least not within the next couple of years. The stock wheels are 17" and this one is 15". My question is, has anyone put a 15" wheel on a non power steering truck? Is it harder to manuver the truck, or is there no real difference? I have no problem driving the truck "at speed" but slow speed manuvers in parking lots are a little difficult. Thanks all.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-03-2007, 01:21 PM | #2 |
Resident Curmudgeon
Re: Anyone have a 15" steering wheel with NON power steering truck?
A steering wheel is a simple machine called a wheel and axle. The principle operation is below:
The wheel and axle is a simple machine consisting of a large wheel rigidly secured to a smaller wheel or shaft, called an axle. When either the wheel or axle turns, the other part also turns. One full revolution of either part causes one full revolution of the other part. When the force is applied to the wheel in order to turn the axle, force is increased and distance and speed are decreased. The mechanical advantage of a wheel and axle is the ratio of the radius of the wheel to the radius of the axle. For simplification, let's assume the diameter of the steering column shaft (axle) is 2 inches. You are going from 8.5:1 mechanical advantage to 7.5:1. Yes, you will notice a difference.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all Last edited by CPNE; 04-03-2007 at 01:30 PM. |
04-03-2007, 01:39 PM | #3 |
Broke and still trying
You'll get used to it. Like anything...takes practice.
04-03-2007, 01:45 PM | #4 |
I know you know it will change the effort.That`s why you asked,right?You want to know how significantly the change will be,right.As in,enough to deter?I say no,like Rdrdave sez.I put a 15" sponge-grip wheel on a`69 Dodge Power Wagon w/manual steering and 14.50/37x16.5 tires and got used to it.And,that was with low speed in the mud 4 wheeling.
04-03-2007, 01:47 PM | #5 |
CPNE, you crack me up man
Thanks for the physics review, it's been a while I KNOW there will be a difference, just curious to see if anyone else has done the swap and what the real physical or "feel" difference is.
04-03-2007, 01:48 PM | #6 | |
My grandpa had a mid 70's power wagon (with power steering) 318, 4 speed, 4x4 and that thing was a blast to drive.... untill the body rusted so bad it fell apart It was used as a snow plow truck.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-03-2007 at 01:51 PM. |
04-03-2007, 01:52 PM | #7 |
Junior Member
I've used a 14" wheel on my 67 before. Sure parking lots can be a little bit of a hassle but like Special-K said, "You Get Used to it". Hell at one point I even had a set of Mickey Thompson 11-32's on the truck. I got so used to the 11-32's that when I took them off and put 255-70's on the truck, I actually thought I had power steering.
04-03-2007, 01:57 PM | #8 | |
Resident Curmudgeon
Well you could overinflate the tires to offset the loss of mechanical advantage. But that would get into a whole new lesson in gas dynamics. You can also "get used" to wearing a shoe 1/2 a size too small. I do have a practical suggestion. Get an early eightys junkyard truck steering wheel an install it. I think they are around 15 inches. If it's drivable, then spend for the wheel you want.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
04-03-2007, 03:01 PM | #9 |
Go ahead and buy it. I had the same setup a while back, and liked it alot better than the original wheel. Gives you more leg room and more comfortable driving.
04-03-2007, 06:48 PM | #10 |
Too many projects
I know the apprehension you're feeling, I too have manual steering and wanted to change wheels. I did, and now have that same wheel (with a GMC cap) and it's not too big of a deal to steer, but it is harder, just keeps me in shape. Just make sure you can use both hands if you're in a tight parking lot, but I do tight maneuvers in my old work lot no problem, just keep it rolling a little bit and you're good to go.
Power steering is for wimps!
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
04-03-2007, 07:08 PM | #11 |
I have a Grant signature series in mine and its no big deal. I think you will be fine since you don't have huge tires.
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress) '09 CTS-V M6 '03 Sierra SWB Z71 '82 Yamaha Seca XJ650R Turbo! '04 Yamaha FZ6 |
04-04-2007, 08:08 AM | #12 |
Thanks fellas
I'm going to try to pick one up at charlotte next weekend, hopefully for a discounted price and no shipping, but I don't remember seeing any last year. Maybe I didn't look hard enough.
