Brake ????
Will the brake booster and MC from a 1/2 ton work on a 3/4 ton, both have disk fronts and drum rears??
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) |
Re: Brake ????
Yeah, but the 3/4 ton ones have dual diaphrams and a lot more griping force, so the 1/2 tonner will probably cause you to have a harded to push pettle than you have now.
Re: Brake ????
Guess I'll have to find a 3/4ton booster, will the MC work ok, or di I need one of those too, and btw IIRC the routing for the brake lines is different from the m/c also, the front fitting goes to the rear brakes, and the rear for the front, or is it visa versa??
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) Last edited by bobthecop; 04-03-2007 at 05:26 PM. |
Re: Brake ????
You can get one from Autozone or the like for $120 ish (new booster with MC) The 3/4 ton is opposite of the 1/2 ton. So your rear would be the front on the 1/2 ton and the same for the frnt to rear.
Re: Brake ????
Thanks,for the info.
