Old 04-03-2007, 06:45 PM   #1
tranz am
tranz am's Avatar
Power steering conversion
Hello Im looking to convert my 69 gmc from manual to power steering. what are my options? Will a box off a latter model work? I would like the quickest ratio I can get. What should I look for? Thanks.
tranz am is offline   Reply With Quote
Old 04-03-2007, 07:38 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Power steering conversion
Pull the complete system off a late model donor. Any GM truck up to '87 or Blazer/Burb to '91 will work.
Take the pump, brackets, hoses, box, rag joint and anything else you think you will need. Everything bolts right up like it belongs there. Wait, it does belong there; what are you waiting for?
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-03-2007, 09:05 PM   #3
jimmydean
jimmydean's Avatar
Some 69's (mine was like this) have to notch the bumper bracket to clear the end of the steering box. You will notice when you hold it up.
Right where the bumper bolts to the frame, you need to trim out the corner.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-03-2007, 10:08 PM   #4
tranz am
tranz am's Avatar
Cool! I was hoping it would be that easy. Now I guess the question is what years and models have the quick ratio boxes in them. Any ideas?
