Old 04-03-2007, 08:26 PM   #1
Slammed66
Needs a Big Block
Slammed66's Avatar
How much to Z , I wanna lay rocker ona 64
Ive read all the post ive seen z's from 2 -6 inches on here , what is the best amount to go I wanna lay rocker thats it I hi8hgly doubt Ill ever lay door in this truck>?
Im about ready to cut , How bigga slice should I make???
soon to be more slammed 66
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 04-03-2007, 09:12 PM   #2
thekid54
Re: How much to Z , I wanna lay rocker ona 64
I have a 3" Z, 3" drop spindles, and bags with an '82 crossmember on my '63 frame with a '62 body. It lays frame, but not rocker. The pinch weld is about 1/16"-1/8" off the ground. I don't think you can lay rocker with these trucks without a body drop?! Here's some pics:
thekid54 is offline   Reply With Quote
Old 04-03-2007, 09:16 PM   #3
Slammed66
Needs a Big Block
Slammed66's Avatar
thats close enough for this guy
what did you do for the back I have an Idea of what Iw ant but nothign is definate yet
Any pics of the back
1964 Short box
1972 K10
Old 04-03-2007, 09:19 PM   #4
thekid54
It's a 2-link with a panhard bar.
Old 04-03-2007, 09:47 PM   #5
Slammed66
Needs a Big Block
Slammed66's Avatar
si it kinda looks like over kill on your notch , How high would be the least I could get a way with????
thats is some awsome work you've done by the way , thats gonna be a kiler truck , and that 235 is too cool...
1964 Short box
1972 K10
Old 04-03-2007, 09:58 PM   #6
thekid54
Thanks for kind words. If I could do it over again I'd make the notch shorter. I wanted to give myself some room so I could run a taller tire. It also helped with the shock location. If it had been lower I'd have trouble finding shocks or have to mount them somewhere else.
It depends on how tall your tire is, but you'd probably be fine with an 8" step notch. I think that is the standard size that everyone else runs. I extended mine to make it taller.
I like 235s...started putting it back together. Here's the split manifold I'm running. Should sound nice with no mufflers!
Old 04-04-2007, 12:58 AM   #7
64shortc10
64shortc10's Avatar
thekid54,
That back setup looks so tight! Where did you get that c-notch it looks great. Are those the stock framerails after the notch? cause the notch looks straight. Also where did you get the upper bag mounts? The only thing I think you should change is your panhard bar. When you lift the back all the way up doesn't your rim hit the frame? Just wanna say again that the truck looks dope. Is it a fleetside? You should put 22's on the front 24's on the rear a cruise that 6 banger! L.A. is alittle far or i'd pay you to bag the back of my 64!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 04-04-2007, 01:29 AM   #8
thekid54
Originally Posted by 64shortc10 View Post
thekid54,
Tony from Norcal
Thanks for the props Tony! The notches are from suicidedoors, but I extended them. Those are the stock frame rails behind the notch. However, I cut the rear cross member and moved the frame rails out to line up with the notch. That way I didn't have to deal with a crooked notch. I made the upper bag mounts using bag plates from suicidedoors. I designed the vertical plates. They're made from 1/4" plate and they tie into the inside of the frame rail for extra strength. As for the panhard bar, maybe it's a bad camera angle, but my wheels don't even come close to hitting the frame. Yes, it's a fleetside, but I still have to shorten my bedsides down from a longbed. Although I like big rims, they won't be going on this truck. I plan to run Cragar SS, Astro Supremes, or Radir Tri-ribs. I'm going for a 60's custom.
Old 04-04-2007, 01:49 AM   #9
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
great looking setup you have there.
what's your plan for the drive shaft? it might be a camera angle, but it appears that your frame will snap it in two when you air it up.
IvelDesigns is offline   Reply With Quote
Old 04-04-2007, 02:48 AM   #10
thekid54
I've notched the crossmember since then. I believe this pic was taken at ride height, or maybe a little higher.
Old 04-04-2007, 07:52 AM   #11
onelow69c10
very nice work
onelow69c10 is offline   Reply With Quote
Old 04-04-2007, 02:35 PM   #12
98L150
///Relaxed Atmosphere
98L150's Avatar
nice work
thekid 54,
what did you do to drop down the engine mounts to move the engine lower?
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 04-04-2007, 03:59 PM   #13
thekid54
Originally Posted by 98L150 View Post
nice work
thekid 54,
I just used the '82 mounts that came with my crossmember and modified them. I used the inner set of holes on the crossmember to mount them and then sectioned them to fit the frame. The mounts for the engine are modifed 230/250 side mounts from a '75 truck.
Before:
After:
Engine bracket:
Old 04-04-2007, 07:19 PM   #14
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That looks killer....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-04-2007, 08:12 PM   #15
98L150
98L150's Avatar
thanks for the pics
72 Suburban
64 Build Thread
Old 04-04-2007, 11:37 PM   #16
56chevy1300
56chevy1300's Avatar
Nice truck...I snapped this pic at Rock n Red Deer last year.
56chevy1300 is offline   Reply With Quote
Old 04-05-2007, 08:54 PM   #17
Slammed66
Needs a Big Block
Slammed66's Avatar
Eeeeeek
I was embarassed to have the truck there , got a flat on the way down hence the ugly steely and , a bad case of crooked bumper syndrome.....
thanks for the compliments tho....
shell be looks real good soon
should have 18's and 20s on it this year too...
1964 Short box
1972 K10
