Old 09-05-2002, 09:29 AM   #1
sam's 72
Need help with getting one piece drive shaft in LWB
I have my truck over at a friend of mine tranny shop, we are putting in a built up 700r4 in it. I want to go with a one piece drive shaft, he calls me today and tells me that he dont think it is a good ideal to cut out the loop that the drive shaft is going through to get the one piece drive shaft in. The rear trailing arms are conected to this. what I want to know is who has done this conversion? And is there any trouble with cutting out the loop to get the single piece shaft in the truck? I know a lot of you guys have done this, what did you do? did you box it back in, or just left it cut out?
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 09-05-2002, 10:03 AM   #2
slam33
slam33's Avatar
You will weaken that crossmember, and that long of a drive shaft will give you problems becuse of the length. It will start to whip in the center. You going to need at least a 4 inch shaft and keep your fingers crossed
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 09-05-2002, 10:24 AM   #3
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
On my Short Bed I used a 1 piece shaft and cut out the hagger for the carrier, BUT on a long bed I think a 1 piece would be too long and you might get wobble at higher speeds.
Think It out
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-05-2002, 01:10 PM   #4
sam's 72
TTT
72 LWB chevy truck.
Pasadena, Texas
Old 09-05-2002, 04:24 PM   #5
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
i saw a lWB at a show that a a 1piece behind a blown 468BB. all he had to do was notch the center loop abount an inch, but he also had what looked to be a 4/6 drop though
-Nic
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
Old 09-05-2002, 07:52 PM   #6
90\87Formula
90\87Formula's Avatar
Most driveline shops will tell you a one piece driveshaft shouldn't be longer than 6 foot. Longer onepieces will create vibration and eventually failure.
It's not necessarilly the diameter, but the wall thickness of the tube.
I went from Powerglide to TH400. I didn't cut out the loop ,but I did have to cut out the piece that held the carrier bearing to the loop.
I wouldn't cut out the loop, these frames flex enough as it is.
Just my .02 cents worth.
Good luck, whatever you do.
Robert
Member 1532
90\87Formula is offline   Reply With Quote
Old 09-05-2002, 08:00 PM   #7
72chevyLWB
Got 20's????
72chevyLWB's Avatar
I have a 700R4 in my truck and HAD a 1pc driveshaft. It does whip in the center which gives you a nasty vibration and eventually loosens your pinion nut. Then the nut comes off and the pinion runs into your carrier and makes a really interesting noise. Oh yeah and then it ruins your rear tranny seal also. DO NOT EVER USE A 1 PIECE DRIVESHAFT ON A LWB TRUCK. You will me much happier with a 2 piece.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 09-05-2002, 08:55 PM   #8
Brad
Out of the carpool lane.
Brad's Avatar
Post
See my replies on this thread:
http://67-72chevytrucks.com/vboard/s...threadid=21656
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-05-2002, 10:40 PM   #9
Tim Christian
Tim Christian's Avatar
Smile
Guys,Guys,Guys About all GMC long wheelbase trucks I have ever seen came factory with a one piece drive shaft. I have owned two of them myself and the drive shaft ran right through the center of the loop from the factory. No whiping, No vibration or nothing. Matter of fact I still have one of the frames laying here in the yard if you would like to see pictures. I also still have one of the factory long one piece drive shafts.
Tim Christian is offline   Reply With Quote
