Old 04-03-2007, 09:17 PM   #1
marvxyz1
marvxyz1's Avatar
attach molding
Does anyone know how to attach molding on the side of the bed of a chevy truck. Mine has little ruberized pads between the body and molding which were originally attached with adhesive. I've tried a couple of adhesives , but have had no luck. Nothing I've tried, sticks to the pads. thanks for any possible help. I believe I tried super glue, for one. marvxyz1
marvxyz1 is offline   Reply With Quote
Old 04-03-2007, 09:20 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: attach molding
Have you tried the 3M adhesice tape that is meant to hold trim on? If that stuff won't do it, nothing will. You can buy it in auto parts stores in the same section as bondo and sandpaper. i think I bought my last pack at Wal-Mart.
Slonaker
EDIT: This stuff
http://multimedia.mmm.com/mws/mediaw...66SS1ec7rrrrQ-
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-03-2007, 09:26 PM   #3
marvxyz1
marvxyz1's Avatar
Re: attach molding
slonaker, is it double sided tape??
Old 04-03-2007, 09:28 PM   #4
marvxyz1
marvxyz1's Avatar
Re: attach molding
Thanks slonaker!!
Old 04-03-2007, 09:51 PM   #5
knightlife
Dark Heart Motorsports
knightlife's Avatar
Re: attach molding
make sure you scrape off the old tape before laying the new...you can use the new tape straight across with a ruler for a spacer too (if that helps), that way its even. on my 76 (a few years ago) I just layed new tape down without scraping the old gunk off the surface, looked like hella azz
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 04-03-2007, 10:45 PM   #6
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: attach molding
if you dont want take and glue will work autozone has some super adhesive weather striping glue. Iv used on every thing and man does it hold. One thing i used it on was the side mirriors they were coming loose after the old heat gun glue from factory wore out. (this it were the mirrior glass stick to the mirrior frame inside the housing)
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-03-2007, 11:47 PM   #7
Slonaker
Slonaker's Avatar
Re: attach molding
Originally Posted by marvxyz1 View Post
Thanks slonaker!!
Sure. You will be really impressed with how well this stuff sticks.
EDIT: I tried an off brand, and it did not work as well as the 3M stuff. It also works great for holding stick-on blind spot mirrors to your side mirrors.
Slonaker
Stock '01 Silverado
Old 04-04-2007, 08:21 PM   #8
marvxyz1
marvxyz1's Avatar
Re: attach molding
Thanks a lot guys, I should be able to finally be able to attach that molding once and for all. with that information...Marvxyz1
Old 04-05-2007, 01:13 AM   #9
andrist1
andrist1's Avatar
Re: attach molding
LMC Truck sells the same pads you are reffering to for $1.95 each
1976 Factory 2wd Blazer - Restored
1975 SWB - Current Project
1978 Big 10 - Just for fun
andrist1 is offline   Reply With Quote
Old 04-05-2007, 08:55 AM   #10
panelguy
panelguy's Avatar
Re: attach molding
dont forget to wipe off the truck with a wax and grease remover after you take off the old tape. Then use masking tape as a guide to get the molding straight.
66 Acadian 2 door
69 GMC panel truck
78 Chevy crew cab dually
79 Chevy blazer 2wd
01 Chevy silverado 2wd reg cab shortbox
panelguy is offline   Reply With Quote
