![]() Join Date: Apr 2007
Sway bar for 69 GMC
Hi I was wondering where I might find A front and rear sway bar set up for my 69 GMC. Rear leaf?
Re: Sway bar for 69 GMC
The front bars are the same from 67 to 87 on pickups - 1/2, 3/4. Quite reasonable at junkyards. Lower control arms have the mounting hole standard. Frame brackets are available from ECE or GM. Some times the bar is mounted directly to the frame without a bracket. The straps and bushing are available from vendors or GM.
I don't know anything about the rear bars with leaf springs.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
The best front bars I find are off of old 70's & 80's tow trucks & HD 3/4 tonnes I find. They are 1 1/4. this is a great FAQ;
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
cool! but what about the rear bar? Any one?
Helwig makes them.Never available from factory on these trucks.Helwig stuff is sold all over the place,such as Summit Racing.
cool thanks.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
its all about the +6 inches
If you happen to see a P/30 or a motor home in the junk yard, you can look for a rear sway bar on them. I know as early as 68 they did. This would be big HD stuff, and in all reality, may be too big a bar to run on a light duty truck with a small bar up front, but even if you installed one and discovered that, a one ton owner on here would pay just about what ever you wanted for it if you decided to remove it.
#8 | |
you winking as you say that??? ![]()
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
no.. .I know that becouse i sold a set up off a 68 P/30 for 150 bucks, and i only paid 25 for it.
Of course... since you have real leaf springs, you could look underneath practicly any truck you come across in the junk yards... chevy, ford, dodge.. what ever you come across. Late model trucks pretty much all have an avalible rear sway bar.
