LAIDOUT
Wiper Motor - its spins or swivels?
I recently got a used wiper motor from a parts supplier when I was ordering some other parts. I went to install it last night and either I don't have it installed correctly, or maybe the motor isn't working correctly...
The motor when activated spins in one direction the arm attached to the wiper linkage [both slow speed and fast speed work this way]. Problem is the linkage at the wipers binds up before one revolution of the arm can be made. My old wiper motor has been dead for so long I can't remember if it stopped and started to move the wiper linkage or just spun in one direction. I know the remedy is simple, but I haven't figured it out... Any suggestions? |
Self-proclaimed LED man
Re: Wiper Motor - its spins or swivels?
i dont think they make a full 360, just sweep left to right.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once ![]() Norwood Survivor |
![]() Join Date: Mar 2003
The motor will spin in one directon, the linkage allows the back and forth. Your linkage may be hooked up wrong
LAIDOUT
I'll try to setup a different configuration for the linkage. Only one way, apparently the wrong way, was obvious to me, will keep trying!
Yes the electric motor travels in one direction and the linkage makes it go back and forth.
Usually there is an offset pin or connection point on the motor to turn the circular motion into linear motion.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
In the picture below is a generic wiper linkage setup. In the top one the motor is in the middle and when it turn the offset pin goes around and around making the arms go back and forth.
![]() Sorry I could not find a diagram of a 67-72 linkage online.....
LAIDOUT
Thanks for the picts! I figured it out tonight. I had the whole linkage reversed, wrong wiper swivel [post where the wiper arm mounts] on the wrong side. I purposely didn't break down the linkage when I removed it, but apparently you can still put it backwards even in one piece. Ah, this kind of education is priceless.
its always nice to learn something new
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
