Old 04-04-2007, 05:27 PM   #1
72 Cheyenne402
72 Cheyenne402's Avatar
POR15 Is it worth the $$$$
The more I read about POR15 I like it but, you seem to have to buy the sealer to preserve the life of POR15 and that isn't cheep either. Does anybosy out there have any experience with this product? Can you spray it or brush it on? I am thinking of putting it on the interior of my bed I have some minor surface rust that I would like to use it on. Any thoughts or Ideas?
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 04-04-2007, 05:31 PM   #2
jimmydean
jimmydean's Avatar
Re: POR15 Is it worth the $$$$
You need to top coat it. Use a brush so you don't waste it and then shoot a color over it.
It is not UV resistant, so you can't just paint it on and leave it exposed. On your frame or under the carpet (like mine) you are fine, but you don't want it exposed to direct sunlight.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-04-2007, 05:54 PM   #3
72 Cheyenne402
So you would paint it on and top coat it and then paint over the top coat? I thought about doing a rino liner. Would it work on this type of application?
Old 04-04-2007, 06:00 PM   #4
jimmydean
jimmydean's Avatar
Just a top coat to cover the POR15.
Rhino Liner would be a good option. That is my plan this summer. I am treating all my bad spots, then shooting the bed. Should be sweet.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-04-2007, 07:59 PM   #5
96blazr
96blazr's Avatar
I found this a few years ago and have never looked back. In my humble opinion, forget POR, use this:
www.rustbullet.com
While I don't have any pics, I did just use this on the inside of my front fender cause it has a little surface rust starting to build on the inside near the radiator. I also plan on using this on the entire frame (and anything else that isn't nailed down).
When I first got it I did an old Axe head and left it out in the weather for a year. Still sharp and still rust free to this day. This stuff is THE S*%T!!!
You can sand it and paint over it all day long. Check out the web-site.
You won't be disappointed.
1968 SWB.
GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators.
Remember, no matter where you go,
There you are.
Gary
96blazr is offline   Reply With Quote
Old 04-04-2007, 09:58 PM   #6
slt0066
i used the rust bullet on my suspension parts and cab floor. i dont have any proof of how long it lasts but im happy with it so far. its a lot easier to apply than por 15. you just clean the dirt and grease off and brush or spray it on. make sure you wear rubber gloves and dont get it on you cause you cant get it off if it dries. i wore it on my hands and arms for bout 2 weeks
it looks real good when sprayed and its tuff as nails almost like powdercoat.
slt0066 is offline   Reply With Quote
Old 04-04-2007, 10:34 PM   #7
Ole Blue 68
Ole Blue 68's Avatar
Whether or not its worth it, I was talking to a guy who has a shop by me and he referred to POR 15 as "paint over repeatedly." He said Tractor Supply has some paint called implement paint or something like that and it works better for a fraction of the cost.
Actually, here's a link:
http://www.mytscstore.com/detail.asp...roductID=18290
Ole Blue 68 is offline   Reply With Quote
Old 04-04-2007, 11:06 PM   #8
pat
pat's Avatar
Thumbs down on POR, go for something like Eastwood Rust Encapsulator. If you have to go through all the trouble of topcoating as well so it doesnt look like crap after a while (like mine), then its not worth it.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 04-04-2007, 11:12 PM   #9
rodstored-72
chevy truck fan
rodstored-72's Avatar
i used por on my chassis when i redid it. i am happy with the outcome i did. it is a little pricy though. i would imagine that all the stuff mentioned above would probably work for what you want. i had just went down to my local paint supply house & that is what they recommended to me. though for sure you want to use gloves & mask when using, especially if you spray. if you spray it better make sure that you cover everything that you don't want black!!!
good luck!!!
rodstored-72 is offline   Reply With Quote
Old 04-04-2007, 11:21 PM   #10
jimmydean
jimmydean's Avatar
I guess I never think about the price since I get it at cost. I have been real happy with POR15 since I am painting over it anyway. I've been using it for over a year now with great results.
I have had bad luck with just about every product I have used from Eastwood. Not only is the stuff overpriced, but a lot of it is junk.
They charge $9 for 8oz of powder when I get it for $5 a pound! I get specialty blends for $10 (you should see my 24k gold metal flake clear, it's awesome).
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-07-2007, 11:35 PM   #11
72 Cheyenne402
Right now I have some stuff called Jasco. I have heard it is good stuff and will never allow the medal to rust again you just have to spray a primer over it. Anyone ever used Jasco?
Old 04-08-2007, 12:03 AM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've been useing POR15 for years, and love it.
Old 04-08-2007, 01:03 PM   #13
spdrcr29
spdrcr29's Avatar
I used POR on the underside of my Caprice hood 7 or 8 years ago, and it still looks like new.....
But, I checked out the Rust Bullet site, and the next project I get working on, I'll give that a try!
spdrcr29 is offline   Reply With Quote
Old 04-08-2007, 01:24 PM   #14
LonghornJeff
EZEKIEL 25:17
LonghornJeff's Avatar
Andy remember to keep the lid on tight.....
68 CHEVELLE(HORSESHOE)
69 LONGHORN 396
70 NOVA 454(FOR SALE)
71 SWB 307
71 EL CAMINO 383
72 GMC JIMMY 350
87 BLAZER 350 WIW?
http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM
Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists.
The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers...
LonghornJeff is offline   Reply With Quote
Old 04-08-2007, 01:43 PM   #15
Longhorn Man
OHHHHHH MAN! I forgot that photo existed!!!!!!
This is a shot of the trunk of my old town car. We were at the second ohio board meet at mike's, and I was out haulin ass in the car getting supplies for mike's new shop, when I tried puttin it on 2 wheels in a corner the POR fell off the high part of the trunk and landed in the pocket there, and broke open. I was unintnentionally huffin that stuff for a few hrs.
Old 04-08-2007, 01:47 PM   #16
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
That sucks but, the inside corner of that trunk will never rust
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-08-2007, 02:03 PM   #17
rambler
MOVE OVER
rambler's Avatar
I've used POR15 as well, on my core support, inside fender wells.. buy cheap brushes and wear latex gloves and throw them away, but seemed to work well for me.. just got to finish putting the truck back together now.
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 04-08-2007, 02:16 PM   #18
kbs71
71 rustless in texas
kbs71's Avatar
I called rustbullet up a couple of months ago to ask about their product and the lady asked if I would like to try a sample. I told her sure, so she asks me for my address, I give it to her and she tells me she's sending me a pint of it out for me to try. A week later I get TWO QUARTS, one silver and another the new Black Shell, with a note asking me to try out their new black product on anything I want. Just to write them or e-mail them back with my opinion of their products. That right there sold me. I've used the black on part of my cab and so far so good. Looks like an excelent product. But my trucks half torn apart, and will be awhile till it's back together again. Painted a old rim with the silver (just knocked the rust off with scotch brite) and it's been sitting outside in the rain and sun for about 5 weeks now. Looks just like it did when I painted it.
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
Last edited by kbs71; 04-08-2007 at 02:18 PM. Reason: I can't spell and the spell check isn't working on this SITE!!!
kbs71 is offline   Reply With Quote
Old 04-08-2007, 10:14 PM   #19
GlennBrittain
I am with Jimmydean on the Eastwood rust products. I will be starting on painting a frame soon, I have not decided what to use yet, but for sure it will not be Eastwood. I used Eastwood on a fuel tank that is showing rust through the paint less than six moths.
GlennBrittain is offline   Reply With Quote
Old 04-08-2007, 11:31 PM   #20
LEEVON
Moderator
LEEVON's Avatar
I'm gonna try this:
http://www2.sherwin-williams.com/che...ctPolaneHS.asp
If it's good enough for Caterpillar, it should hold well on a frame. And much cheaper than POR15.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-09-2007, 06:58 AM   #21
dave3156
Only use POR15 in a well ventilated area. One board member almost died when he sprayed it. He broke out in a fever, had a rash and was sick. As far as it lasting: I put some on my truck floor 2 years ago. I did it in my buddy's shop and spilled a couple drops on the shop floor. The spots are still there on the concrete and will probably always be there. I bought a quart and it took a long time to use it up. It has to be refrigerated once open. It goes a long way. I top coat mine with Rustoleum, seems to work good.
dave3156 is offline   Reply With Quote
Old 04-09-2007, 07:10 AM   #22
arkracing
Weekend Warrior
Can't spray it unless you have a "Fresh-Air Mask" - POR has ISOCYNATES or whatever in it = very bad to breathe in. I actually sprayed some without knowning that - I wore a regular mask and had no ill effects but it was in a well ventilated area.
Then as stated before you have to paint over it with thier Top-Coat and all this money making B.S.
(However I do like POR Engine Enamel, and that can be sprayed as it is just regular enamel with a high solids base to it)
That Rust Bullet Stuff looks like something I would try. And you can paint right over it!!!
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 04-09-2007, 08:18 AM   #23
cdowns
cdowns's Avatar
i've been using POR15 for many years and have found best results with painting it then while its still slightly tacky spraying my finish coat on . i get excellent adhesion that way i usually use an enamel for my finish coat
eastwood stuff is just overpriced rebranded brandX/ they dont manufacture anything
