Seņor Member
Question for our gauge experts out there
Will the "base" gauge set (speedo, center thingie, fuel) bolt up to a "loaded" gauge set's bezel? Obviously, I realize that there would be 4 holes at the bottom of the bezel that didn't have anything in them. I just want to know if they'll even bolt up together.
Also, if I were to convert from base instrument panel to the full panel, does the base wiring harness/plug still work for the base gauges? That is, can I swap panels and my gas, signal indicators, high beam indicator, etc., still work... and I would just have 4 gauges on the bottom that weren't working?? Thanks in advance, Kenneth
CCRider
This page has most of the imformation you asked for.
http://www.gmcpaulstruckparts.com/Tech%20Tips1.htm
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
You are trying to confuse everbody right :-)
The wiring for the connector which plugs into the printed circuit on the backside of the guage panel and indicator panel are different. What I mean is they are the same physical demisions (the connector) but the wires are located in different places. In other words: If you are changing from a indicator panel to a guage panel your plug will have to be rewired for the new panel. It is just a matter of switching around the wires on the connector. Someone on the board has a link to a diagram which shows what wires go where. I think it is on GMC Pauls website.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
#4 | |
Seņor Member
![]() What I'm contemplating in my first question is simply running the base idiot light gauges, but mounting them into a gauge dash panel like this-- ![]() That would leave me with 4 holes across the bottom. Does that clarify? As for my second question, it looks like tom hand's link is what I'd need. Thanks Tom! The two questions are mutually exclusive scenarios of how I might handle my dash gauge issues. Thanks, Kenneth
You can buy a new pannel with out the holes in the bottom if that will help. They have just started making them. they cost a little more than the full pannel though
69-C10 LWB 71- fleetside shortbed It's a shame stupidity isn't painful Never play leapfrog with a unicorn |
#6 | |
Seņor Member
![]() Kenneth
Yes, I put my stock idiot light speedo, and fuel guage set, into a new multi guage bezel. This way you can still use the stock wiring harness and your fuel guage will still work. the bottom holes, you can use to hook up mechanical guages. I think I had to trim some of the tin black medal cover on the back, but they did fit. I pulled the bulbs out of the center idiot light section, and used a clear guage piece out of a used multi gauge dash.
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
#8 | |
Seņor Member
Kenneth
![]() Join Date: Aug 2001
What's your plan for the 4 extra holes along the bottom and the turn signal holes?
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
I was thinking of doing just the opposite xxl. . . I was wanting to use my beaters stock 3 guage bezel & just mount the factory tach in the center location. Since I'm using mechanical guages for oil psi & water temp I really don't have a use for the remaining fact guages & I kinda like the look of the flat bezel w/o the extra holes. I figured the wiring schematic would be slightly different.
#11 | |
Seņor Member
{phew... that was a lot} Kenneth
chevelito
sup kenneth,
I was thinking of the same setup but probably will drill the holes in my 3 hole dash to fit the air guages since I think they are smaller. We'll see, I'm still a long ways off from that. jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
#13 | |
Seņor Member
Any other ideas, anyone? Kenneth
#14 |
It's just me but the reason I started smoothing my dash and with a dash as smooth as yours, I'd want to hide everything possible. I guess your trying to do that but seeing the igintion switch out in the open just doesn't fit with the smooth style. I know...I'm a fine one to be talking, I still don't have a permenat location for my ignition either.
![]() Btw - do you still have your old switches from the 2-way system? or was making a 4-way system accomplished by adding 2 more 2-ways?
#15 | |
Seņor Member
![]() On the switches, etc., The RideTech system is expanded from 2 to 4-way by adding a second solenoid block. The actual electric switches they offered had changed styles since I bought the first ones so I got an extra pair of the new style. The old switches and about a dozen "samples" I got from the switch manufacturer (I have a total mind block on the manufacturer right now. I'll let you know if I think of it). Kenneth
#16 | |
Seņor Member
Kenneth
#17 | |
chevelito
You are a man of your word....awesome. This will be going to my tech file. What did u use? a dremel?
#18 | |
Seņor Member
![]() Kenneth
#19 |
chevelito
ok...contemplating some more here...I saw zkast's truck with these new seats and maybe I could put the switches and guages in the fold down arm rest. Maybe you could put the accesorry switches in there....yeah I know...it's a stretch. If I do put these seats, it will be minus the head rests:
#20 |
Seņor Member
jay-dawg I like those seats a lot, and I agree with you about the headrests. As for putting the gauges in the center section, it really depends on what kind of gauges you go with. Mine are mechanical gauges, so they have 1/8" air lines running to them. The folding up and down of the center might pinch a line... or worse, break one (since they're in the air system, if the line breaks, that corner of the truck lowers itself to the ground
![]() BTW, what is that seat out of? Pre-99 Tahoe? Whatever it is, if anyone in the MA area has one of these in excellent condition, from a non-smoker's vehicle, and in the same gray material, I'd be interested if you're selling (it's a stretch, but I thought I'd ask anyway). Keep us posted! Kenneth
#21 |
chevelito
sup kenneth,
here's the info on the seats: http://67-72chevytrucks.com/vboard/s...threadid=22178 BTW, got some work done on the truck. I took out the rear shocks and coils and set it down on the axle (I left the bumpstop in). I tell you, it's getting me excited seeing the backend that low. I'd post some pics but I dont have a digi. jay
