Old 04-04-2007, 08:16 PM   #1
brak
brak's Avatar
Steering coupler (rag joint) Splines???
I picked up a new steering coupler for my truck (converting to power steering) and noticed that the coupler does not have any splines, it's perfectly smooth inside...
Does that sound right?
I know power steering doesn't require much effort, but what's to keep it from slipping and not turning the input shaft (which is splined BTW).
It just doesn't seem right.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 04-05-2007, 01:53 AM   #2
sjarrett71
sjarrett71's Avatar
Re: Steering coupler (rag joint) Splines???
I've never seen one that wasn't splined.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 04-05-2007, 02:36 AM   #3
brak
brak's Avatar
yeah, i thought it was wierd...
I'll post a pic in the morning when i get home from work
Old 04-05-2007, 04:23 PM   #4
brak
brak's Avatar
ok, it turns out that one section has splines (less than a 1/4 of the inner radius) and the rest is completely smooth.
Still doesn't seem right to me...
Old 04-05-2007, 07:40 PM   #5
flatheadnut0
New Member
Brak,
I just changed my 67 over to power steering that came out of a 78 and everything was splined. My column was out of a 87 van and it was splined also. I put the old rag joint on the gear box and used the old double d shaft cut to measure to a borgeson knuckle to the column.
flatheadnut0 is offline   Reply With Quote
