04-04-2007, 08:17 PM | #1 |
TH350 Questions
First off, I haven’t been to this site in years. It’s HUGE now- wow!!
I am interested in information about 4X4 th350’s. are they shorter than a short shaft 350? Measuring from bell housing to end of shaft, not end of case. Is the shaft splined the same as a regular 350? (28 spline) Or is it a gear that mates up with the gears in the transfer case? Thank you for your time! |
04-04-2007, 10:18 PM | #2 |
Re: TH350 Questions
th350 is 27 splines
alot of the original cases have a big ass K on them
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS Last edited by stan79chevy; 04-04-2007 at 10:26 PM. Reason: more information |
04-04-2007, 11:49 PM | #3 |
Re: TH350 Questions
The main case is the same. The 4x output shaft sticks out the back of the case about 1''
04-05-2007, 12:13 AM | #4 |
Re: TH350 Questions
Yep,the case is the same,the difference is that on a 2wd the extension of the case for the longer shaft bolts to where the adapter plate would bolt to for a 4x4.
And as Stan said....There is a "K" in the case of a 4x4 TH350. Last edited by 1969k10stepside; 04-05-2007 at 12:17 AM. |
