![]() Join Date: Apr 2007
Any reason to swap from 6 lug to 5?
I was just curious if there are any benefits to going to 5 lug rather that keeping the 6 lug. I plan to convert to disk so I have the option?
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
Insert Title Here
Re: Any reason to swap from 6 lug to 5?
better choice in wheels is the main reason
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Yeah. Try finding nice wheels for a 3/4 ton. Not a whole lot of options.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
looks like 5 lug is the way to go. Where I might find the five lug axles is the question now?
#8 | |
Insert Title Here
http://www.classicperform.com/Store/...6366RWBK5E.htm
Everyone pretty much nailed it. I would suggest that you pick out what rims you want first and let them dictate the bolt pattern. I switched to 6 but then all the rims I liked were 5 so now I'm kinda screwed. Also, I dont know a whole lot about the axles but i would think taking a whole one off a 67-70 half ton would be the easiest way unless you feel like taking one apart and taking just the stuff you need.
69 shorty w/ 67 front clip ![]() |
i would try summit or lmc truck or brothers
Well I would like to beef up the axle shafts any ways to handle the torque of a 454. I would imagine that jegs or summit may be able to help me there.
do you have the contact info for imc truck?
#13 |
BlahBlahBlah
I'm doing the disk conversion and keeping 6 lugs. Going to be running stock steel wheels so wheel selection didn't matter to me. I also didn't want the added expense of changing out my rear axles or complete rear end. It all adds up.
#14 |
I hear ya.
#15 |
5 lug will allow you to easily install rear discs, ie Impala or Camaro calipers, rather than the more expensive Kits.
summit carries 5 lug axles...
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 04-05-2007 at 01:55 AM. |
#16 | |
![]() Join Date: Mar 2005
cg,i don't know if you have tried it or not but my stock wheels will not go on my 6 lug disc rotors.if i tighten the lugs all the way down the wheel hits the calipers.i'm running aftermarket wheels so it's ok with me,but if i have a flat i hope it's not on the front.... |
#17 |
Hand Crafted C-10
![]() Join Date: Aug 2006
I went with 6-lug rotors, on my C-10, rather than try to find the correct length axles. ...no regrets; drove with 22 lug nuts for far too many years. Also helps maintain the stock appearance of the truck.
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
#18 |
![]() Join Date: Aug 2005
I'm in the process of swapping so I maybe be speaking to soon but I would recommend going with a 73-87 swap for three reasons. 1) disc brakes 2) 5 lug 3) cheap a$$ parts. Compare part prices.
CPP is selling 6 lug rotors for $129/pair plus shipping. You can pick up 73-87 rotors at your local parts store for $30 a piece. Last edited by Ole Blue 68; 04-05-2007 at 10:22 AM. |
#19 |
Oh yes, let's all make our trucks weaker so that they look cooler. If you did have a 3/4 ton (8 lugs), and you were dead set on 5 lug wheels, if it is 4x4, sell it to someone who will use it, and buy a 1/2 ton. Guys wanting to do serious off-roading would appreciate being able to start off with a tougher truck.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. |
#20 |
So the 5 lug setup is weaker than the 6? I wouldn't imagine it would be to much of a difference, I mean if you used hardened studs wouldn't it be stronger?
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 04-05-2007 at 11:29 AM. |
#21 |
Insert Title Here
no, the more lugs you have the more torque it has holding the wheels on..... thats why all the Mustang guys go from 4 to 5.... but as long as your not climping hills and jumping rocks I wouldnt even worry about it
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 04-05-2007 at 01:55 PM. |
#22 | |
![]() Join Date: Nov 2004
![]() He wants to swap from 6 lug to 5. The 1/2 ton trucks came stock with 5 lugs in 71-72.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#23 |
No. I doubt I will be jumping rocks much. I'm setting this up as a street machine. Not a lifted 4x4 mud jumper.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 04-05-2007 at 12:03 PM. |
#24 |
Insert Title Here
5 lugs is plenty to hold it together, maybe going form 8 lugs to 5 might effect something, i dunno
#25 |
![]() Join Date: Jul 2006
I kept the 6 lug setup when I went to disc in the front. I went with 6 lug ralley's but there are quite a few 6 lug aftermarket options. Not as much as 5 lug though.
