Anywhere i could find a steering column shifter spring?
i lost my spring and was wondering if anyone new the type of spring it is and where i could buy one... thanks alot.
Re: Anywhere i could find a steering column shifter spring?
Is your column a tilt or non-tilt?
Around here compression springs are availabe at the local hardware that can be cut to length. I can measure a spring and post the dimensions if you let me know which one to measure. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
its all about the +6 inches
if it is a tilt, go to the dealer. P/N 1894851
If it is a non tilt... there is no spring. |
it is tilt....thanks guys
so anywhere else i could find this?
sufficiently talented fool
![]() Join Date: Jun 2006
Go to the dealer. It is probably under $5. I don't believe anyone aftermarket makes it, unless you match it up at a hardware store. It is also not worth the effort to remove one at a junkyard.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
the dealer?? what dealer? the GM dealership?
BlahBlahBlah
no like seriously you think they still carry these?
#13 |
my guess would be yes, because they still have the tilts and i doubt they changed the spring, but i would try them first with the P/N 1894851 from Longhorn Man before you try the hardware store
#14 |
You would be surprised what they still have at the Chevy dealers. In the past 2 months, I bought the sport mirrors and a rear tag frame from Chevrolet. The spring in the tilt column is probably the same as the newer units, and is probably still available.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board Last edited by centsless; 04-05-2007 at 10:00 PM. |
#15 | |
you can still get the style mirriors from these trucks? and whats a rear tag frame?
#16 |
yes, the spring is still avalible from the dealer, and most likely it is in stock. I've bought about 200 or so for the trucks we were rebuilding at work.
