04-05-2007, 12:05 PM | #1 |
hydro boost
hello to everyone. I am new to here and just wanted to say what a great place to be. After reading all the threads on here I figured that this would be a great place to get a question answered. Has anyone converted thier four wheel drive blazer over to hydro boost brakes and if you have what did you use and what problems did you encounter? thanks
04-05-2007, 12:39 PM | #2 |
Post Whore
Re: hydro boost
Welcome to the board. I did this on my 69 K20 and my info will all apply to your K5. Check out this link and let me know if you have any questions.
Got any pics of your K5 that you can post?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
04-05-2007, 12:56 PM | #3 |
Re: hydro boost
haven't got any pics as of yet but should have some coming soon. thanks for the link. How do you like the hydro on you k20?
04-05-2007, 02:54 PM | #4 | |
Re: hydro boost
Mike
Mike Redpath |
04-09-2007, 05:38 PM | #5 |
Post Whore
Re: hydro boost
I like the hydroboost alot - sure beats the manual brakes!!
04-10-2007, 10:19 AM | #6 |
Re: hydro boost
Dumb question but can you explain this mod to a dummy?
04-10-2007, 11:27 AM | #7 |
Post Whore
Re: hydro boost
The hydroboost uses the power steering pump to make the brakes "power" brakes like the normal power brakes use engine vacuum. For people with modified engines and low vacuum, the hydroboost is a good option since it doesn't work off of engine vacuum. They hydroboost master setup is more compact than the normal vacuum power brake setup, though you do have more hydraulic lines to get it all connected.
04-10-2007, 12:01 PM | #8 |
Re: hydro boost
here is a pic
Mike Redpath |
04-10-2007, 12:35 PM | #9 |
Re: hydro boost
So where would I get this set-up from? I can steal one from a later model truck? Do I need a different steering pump?
04-10-2007, 12:43 PM | #10 |
Re: hydro boost
Find a chevy truck/suburban/blazer that has a diesel and pull everything from it. I think the 73-newer 1-tons also came with it.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
04-10-2007, 01:46 PM | #11 | |
Re: hydro boost
Mike
Mike Redpath |
