04-05-2007, 01:10 PM | #1 |
What Parts do I need from a 73-87 to accomplish 67-72 5 lug conversion
I'm currently trying to convert to 5 lug now on my 69 GMC. I was told that I could use all the parts from a 73-87 to accomplish this. What needs to be swapped is the question? Do I need to pull the whole front control arm assembly off, or just the spindles and outward?
On the rear can I just rip the whole axle housing out and bolt it onto the 2.25 springs or do I have to rip it out the springs and use them? Out of all the 73-87 1/2 ton rearends, what is the strongest and most performance oriented? I will be putting a lot of power to it.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
04-05-2007, 07:31 PM | #2 |
Hellasick
Re: What Parts do I need from a 73-87 to accomplish 67-72 5 lug conversion
You need from the spindles out. Use the donor year ball joints, they fit right into your control arms. Not sure about the tierod ends, yet. I think there may be some issues based on the actual year used.
I'm using an '85 for the donor parts. Waiting for the 6 bolt rotors from CPP, supposed to be here tomorrow. Check out the FAQ section also.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
04-05-2007, 09:43 PM | #3 |
The 73-87 a-arms will interchange & have 'better' bushings in that they offer more cushion for the ride vs. the 67-72 rubber-lined steel style.
Make sure your donor truck has the H.D. 1.25" thick rotors & not the L.D. 1" rotors if you plan to re-use the brake stuff. If you're buying new brake stuff & aftermarket spindles, it won't really matter.
04-05-2007, 09:47 PM | #4 |
Responded to your pm Tranzam sorry for not getting back sooner, our server went down at work.
Here's a post from not too long ago. http://67-72chevytrucks.com/vboard/s...ght=73-87+part There's more, just do an advanced search. |
04-05-2007, 09:48 PM | #5 | |
If you go for a donor, look for 73-75 or so, they'll have the 1.25. Last edited by Ole Blue 68; 04-05-2007 at 09:49 PM. |
04-05-2007, 10:19 PM | #6 |
Always Fixing Things
Uhm, okay I'm a dork but, isn't 6 better than 5? What are the advantages of the swap?
Just an Average Joe ‘68 GMC 307 3spd – My dad's original truck 310,000 miles |
04-05-2007, 10:20 PM | #7 |
BlahBlahBlah
Five lug is disk brakes...you can convert to 6 lug disks with aftermarket stuff. Probably cheaper to just swap out the whole front cross member.
04-05-2007, 10:39 PM | #8 |
You can also use the 73-78 hard lines & prop valve. They fit the 67-72 frame w/minor tweaking.
04-06-2007, 12:42 AM | #9 |
Cool thanks for the info. Ive been super busy in the junk yard today. This is all very useful info. Its going to save me a lot of money.
The only thing now is the rear ends. What does it take to swap out the whole unit to a later model. Are the axles interchangeable?
04-06-2007, 02:30 AM | #10 | |
A guy with a truck
EDIT: Unless it's a late '70 in which case the axles are the same length. As for the front: use everything from the a-arms outward. Also take the entire steering linkage so that you are not having to adapt inner/outer tie rods. Steal the power steering box and pump too if you need it. Bolts right up. -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-06-2007 at 02:34 AM. |
04-06-2007, 07:31 AM | #11 |
Weekend Warrior
Not to be a Biotch - but there are a ton of threads about this - do a search!!!!!
That being said - grab everything - A-Arms, Spindles, ALL Steering stuff, PropValve. The tie-rod ends are differant - so it is just easier to use the entire set-up from the donor IF you swap the entire crossmember you will need to use '73+ brake hoses (The rubber ones) If you swap parts onto your '67-'72 Crossmember - you will need to use '71-'72 Brake hoses. They will work with the '73+ Calipers but they work better with the '71-'72 Calipers (If you use the '71-'72 Calipers make sure that you have the HD rotors as mentioned before)
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 04-06-2007 at 07:34 AM. |
04-06-2007, 11:42 AM | #12 |
Actually, you can use 73-up hose's even if you just swap parts to your existing crossmember. There were holes already in the frame on my 68 so that's what I did....
04-06-2007, 06:28 PM | #13 |
Cool thanks for all the good info I willl return to the junk yard this weekend.
